TOYOTA TIS Techstream
I run mine in evaluation mode. It quits working after a few uses, but I just keep a snapshot from before the 1st time I ran the software, and just go back to that.
That's what I'm trying to use. But, I can only click evaluation after I put in a bogus registration number. The button isn't clickable without a key.
Seat belt chime is no more! It's the small victories that make you feel good.
Still can't find a way to unlock with 1 button press. How did you guys do this? I don't see the option for "unlock key twice" like some of the other Techstream screen shots.
Geez, I'm beyond frustrated with this. I've installed the software 8.20.019, installed the VCI driver and got the red light. When I click connect to vehicle, I can't get past the registration key. What am I doing wrong? I have 3 codes, and none of them work. HELP!!! I should say that I'm running XP through a virtual session.
[Registration - NA]
caacf490093c0cca6b6b148b84362f6fbfa092b0fe31ea
d2307c4ceff1997f9ed19353507f177c30001307260416
70a43662a67870491145543a7042df9fa9fbc0aaf5d686
I'm having the exact same problem, install everything as per the video (included) instructions and the software will not accept the key. Software ID should show 555555555555555555555555555555555 but instead is some random series of numbers. Unlike you I cannot even click on evaluate after entering a key. Version is 8.20.019 and have tried latest 8.30.23 and still no go.
On another note, I am using win7 pro 64b and the drivers have automatically installed for the VCI cable!
You didn't replace the mainmenu executable if it's not showing all 5s.
Installed on Mac using Parallels and XP SP3
Ordered my xhorse cable from carucare, downloaded TIS 8.10.021 from ODB Resource (free) and got into my 2011 tonight. Wanted to practice on this vehicle before my 2014 comes in. If anyone is in the NY/NJ area and wants to swing by to use it, you are more than welcome.
Are you able to see the data lists? I can see the trouble codes and change the customisable options, but get a "fatal error" when I click the data list.
I've replaced it half a dozen times with no change, just like the instructions said.
Have you tried completely uninstalling? I found it leaves a lot of info behind. If you manually delete the folder in you 'my documents' after uninstalling it will do a full new install.
Where'd you find TIS 8.10.021 , I only see Toyota Techstream V7.31.000 on their downloads page? OBDResource Online Store - Software Download
I hear THEre are PIRATEs in the BAY. May want to check it out.
Right I got it. Deinstalled, ran search for anything techstream related in folders and regedit. Reinstalled 8.20.something from the disc, then did the 8.30.something update from here and used the mainmenu from here. All good.
Still haven't figured out how to connect to the truck...
does it matter what connector I get either on ebay or amazon? I am looking thru the items and I have no clue if there is a difference.
as long as I get the Toyota mini vci I should be good?
Toyota Mini VCI Tis Techstream J2534 OBD2 Diagnostic Scanner Software | eBay
this is the only usa dealer I can find, the rest are from china or wherever.
any comments are greatly appreciated.
I've heard of knockoffs that don't work correctly, so I would be careful. The cable I purchased did come from China, took 10 days to deliver, but is legit and works exactly as it should. I can highly recommend this site. Here is the link to the cable for 29.99 and free shipping: MINI VCI for Toyota TIS Techstream V8.10.021Free shipping 29.99USD
In this pic there's a button that says "Generic OBDII" Does that mean I can use TechStream to pull codes from other OBDII equipped vehicles besides Toyotas?
Anyone tried?
Screenshot2012-08-29at93223PM.png~original
Freddygino324
