CutthroatSlam
Senior Member
How to make a fluid transfer pump
1 gallon pump sprayer ($10 Home Depot)
10 ft 1/4”id x 3/8”od clear vinyl tubing ($3.25 Home Depot)
1/4”x1/4” or 3/8”x3/8” mini ball valve with barb ends. ($12 for two on Amazon)
Optional: hose clamps or zip ties for added security at high pressure.
Remove original tubing from sprayer and replace with the clear tubing.
Cut tubing to desired length. I made mine long enough reach without the need to drag it under the truck.
Add the ball valve to the end.
Cut additional length of tubing to reach from ball valve into fill hole securely.
Done.
If you want to establish a baseline level in your pump, fill it with a qt of your desired fluid and pump it back into the original container to see how much stays in the pump. It’s usually only a few ounces.
Pics on this thread.
https://www.toyota-4runner.org/5th-gen-t4rs/117482-front-rear-diff-fluid-change-12.html#post3522444
I used this for the transmission flush. Used the old fluid to flush out the residual differential oil first, then filled with new ATF fluid.
