Some good thoughts and suggestions in this Thread...
Sure, gear down when you encounter a hill (even when not towing, I'd say, and if it's a San Fransisco kinda steep hill!).
My personal "warning light" when using Torque Pro: if the transmission temp crosses the water temp. This is very conservative (occurs around 210F in my experience), the transmission fluid can certainly tolerate more. I did see this crossover in temperature *ONCE*, then I installed a large (22,000GVW) cooler. Now, it never comes close, even with full load (4500lb trailer and all the "stuff").
BTW - the Toyota WS (World) ATF is basically Dexron 4 - which is basically Dexron III but in synthetic. Probably a reasonable choice in 2003 when these transmissions were developed for the one-ton T100, but pretty much anything "modern" will have improved specs *across the board*. So, IMHO feel free to top up or flush with Dexron VI from your local parts-store
