TRD Pro with 6112 coils (pics inside)
Where did you pick up your springs only, all the searches return complete sets. Or did you get them off another member like the OP?
Yes I bought them off of a member that upgraded to 650#. There was another set for sale in the classified the other day. There is also a member selling a set of 14"X3" 600# TRD spring too. They are from an FJ ultimate trail kit. I would have gotten those if I would have seen them first, for the simple fact that they are red.
Youre in Vegas? Come by my shop and I have a set of 600x13 takeoffs Id sell to ya for $80. They are Eibach brand. :reddance:
I am in vegas but looking for the 14” for the added lift. These rocks out here make the trails a little rough. Do you have the t13s?
Don’t you think that would be a bit stiff with no added weight?
650 will give you approximately 3.25in of lift over stock non TRD Pro 4runner or approximately 2.25in over a TRD Pro. You will most likely need new upper control arms. It will most likely be a lot stiffer than what you have on now.
Yeah, that’s more than what I want to do right now... the small increase in price for the 600 3x14 is much better than the cost of UCAs.
I don't understand. You said you put 6112 on your TRD Pro which I assuming you took the OEM TRD Pro Bilsteins off. Were the 6112 not adjustable height?
The stock 6112 shocks do have clip settings so hopefully he did this correctly. They have only 2 settings but DS belongs on the top clip and PS belongs on the lower clip.
P/N for Coils
Hey [MENTION=75956]speedyglx[/MENTION] & [MENTION=303056]Bayou_Pro[/MENTION]
For reference, what is the p/n for the bilstein coils you are using?
E4-FD1-Y005B29?
E4-FD1-Y005B29?
Yep.
[MENTION=75956]speedyglx[/MENTION] are you still enjoying this setup? Thinking about pulling the trigger. Economical lift while still looking good, not too over the top!
Just received the 14x3 600lb coils from a 6112 kit, I will be replacing the stock pro coils and the toytec spacers from the pro lift kit with these coils. I’ll post my results in a few weeks after the install.
Yes still loving this set up. Zero issues. I would it again if I had to.
PRWhite
