Blacksunshyne
Today I have installed a Kicker amp in the 4runner, while trying to keep the stock nav head unit in my trail. For input source I tapped the front right dash speaker wires (pink was positive and yellow was negative...I believe) and wired in a PAC Model # SNI-35 2 channel line output converter, then ran the RCA cables to the amp for an input source. The LOC is turned all the way up, and I have tried every setting in between. I tapped into the cig lighter/12v acc power wire for my remote turn on, ran a 4 guage wire, with fuse, from BATT+ to power the amp, used a 4 guage ground wire, cleaned the ground source and grounded to the body at a front seat bolt. I ran 14g speaker wires along the passenger side of truck to the rear to hook up sub. The sub is working but at very low levels or low volume.
The amp is an older Kicker KX150.2 150W amp that I had used in my previous truck . The amp power light comes on, and the sub plays, but again at a very low volume. I had used the amp because I had it laying around, after pulling it out of my truck about 2 years ago. In that time it has been on a self here in my house. It is driving a single 12" Diamond 4ohm dual voice coil sub for test purposes today until my JL 8 comes on UPS tomorrow. This pairing worked great in my truck, and now it is not work as it should.
Could the amp have gone bad, or have I left out a very important step...which is entirely possible, wiring is far from my strong point. Any help from the wiring gurus here would be greatly appreciated!! :thanks:
