What year and trim are you guys using for parts? I don't this it matterss just wanted see what you are using and just to make sure before buying parts. I was going to get parts from 2005 V8 4x4 Tundra.
Should work.
For the larger calipers make sure they are the 13WL casting. That's what I have on mine. Check out my build thread.
did you use all from the 03 Tundra?
maybe 04, but they are the same. like the other guy above me said, also check out the link.
you need 2 calipers, 2 rotors and a set of brake pads.
once you trim the dust shield back everything bolts in place.
What about the flex line?
You all are assuming he has the wheels (or spacers) to clear the later 213 castings. If not, then he needs stuff from an earlier Tundra for the 199 casting....
Flex lines are the same. The system goes as follows:
Master Cylinder --> Hard Line --> Flex Line --> Hard Line --> Caliper
Same question..
I'm try to search right for stainless brake lines. What are use guys using, brands, cost, & part number?
