tundra brakes - what year range?
runner823
What year and trim are you guys using for parts? I don't this it matterss just wanted see what you are using and just to make sure before buying parts. I was going to get parts from 2005 V8 4x4 Tundra.
Should work.
For the larger calipers make sure they are the 13WL casting. That's what I have on mine. Check out my build thread.
You all are assuming he has the wheels (or spacers) to clear the later 213 castings. If not, then he needs stuff from an earlier Tundra for the 199 casting....
Flex lines are the same. The system goes as follows:
Master Cylinder --> Hard Line --> Flex Line --> Hard Line --> Caliper
I have the factory gen3 five star rims. I know that it will fit 13WL calipers without spacer.
Yes i have the correct wheels 5 star factory 16's but i also have wheel spacers (not needed with these wheels tho)
Same question..
I'm try to search right for stainless brake lines. What are use guys using, brands, cost, & part number?
the brake lines bolt right up. you dont need to buy anything for new lines. just brake parts.
What about the flex line?
dont need them.
