uball joint bolt fell out after cornfed install
irwinSR5
Just wanted to update you guys on my current situation just to make sure anyone installing this kit pays attention to this. The story:
I was at work, went to subway for lunch, as i was backing up I heard a large grinding / clanking sound and the 4runner stopped backing up although the engine was still reving. I originally thought that this was something related to either the transmission or the differential due to it only happening in reverse, and when turning the wheel. I brought it to the dealer (drive still worked although steering was a bit scary) and they began to look at it. I got a call from them stating that the front left uball joint bolt had come loose and fell out. I was waiting for them to tell me that this was due to the suspension lift although I had brought the 4runner to them a month ago to do an alignment and paid another $100 for them to check the suspension components and make sure everything was how it should be.
They called me back and tried to screw me on the cost although after a long argument I got them to cover it due their lack of catching the problem a month ago. I just wanted to make sure that anyone else installing the kit remembers to torque this bolt correctly (although I believe we did after installing) just to make sure this doesn't happen to them. I'm sure this is probably an installation error on our part however just thought I'd let you all know.
the 4runner is back and everything seems fine now.. not sure if this bolt mishap happened during install or during alignment. I just loctite on majority of bolts during install and the people that helped me have done the install several times on different 4runners
WTF is a "uball joint"?? Is this something new, specific to a 4Runner that I have not seen, or do you mean a "Ball Joint", the four axis joints on the upper and lower A-Arms that the spindle connects to?
it may be the 'ball joint' i'm not sure specifically what it is, it is in the front left wheel well so i'm sure what you described is correct
When removing and installing the upper ball joint, there is a cotter pin inserted into the end of the bolt to keep the whole ass'y together. I'm glad you noticed this while backing up and not while on the highway.
100_1126.jpg~original
