Ultra gauntlet and duratrac question
Hey OP, I was looking at these very same wheels and a set of Ultra's "Worx" series. Any experience with pot holes/ off road?
Did the balance fix the vibrations? I am looking at a similar set-up. Just haven't pulled the trigger yet. Also, can the stock TPMS sensors be used?
I recently did a swap from stock LE tires/rims to BFG KO2 on TE rims. The installer swapped over the stock TPMS to the new setup with no reprogramming. He was nice enough to put rubber stems in the old set so I could sell them as a unit. Careful, some tire places wanted a couple hundred to do the swap. My local guy did the stem swap plus the mounting/balancing of the new tires for only $20/wheel.
Awesome! Thank you for that info.
Finally got them put on. They rub a little on the fender liner and the mudflap covering the bodymount. LOVE the way they look.
Anybody else with the duratracs have the steering wheel shake around 50mph? Think I may just need to get them balanced again.
FC3C2B55-AB0E-42C3-A1E1-7813887AF16B_zpsqpmnkbbu.jpg~original
FCE035E9-261A-4BE9-8E12-9B20D23F3D28_zpsznqwftac.jpg~original
OP, you still getting that shake? I have same wheels on my 13 Tac and it shakes. Balanced three times, machine says balanced and still no dice. The tires are Hankook dynapros that had no shake on the stock wheels. Took to dealer and had road force balances and although its better it still shakes. Hub bore is right on, wondering if these rims are just junk.
AndiGarage
