Unsure of what knock sensor to use
inscarguy
Member
Just got a knock sensor code for my '06 V8 4runner. I pulled the intake and the wiring is OK.
What knock sensor should I use?
OEM is 188 each( getting 2 )
Delphi is 68.00 each ( getting 2 )
No real Denso found ( all densos found are counterfeits )
Thanks.
used OEM and replaced starter with Denso reman while there, was around 280K then so figured I'd replace everything while I had my intake off. 2004 though and intake is a bit heavier than 2006 V8.
patnewton
