Upper ball joint fix threads
jack.hanks02
Has anyone been able to use a die or thread file to fix the threads on upper ball joints and or outer tie rods?
I bought a die, but I don't think it's the right size. Swore the bolt was 12mm but my calipers tell me it's 13.5mm. I don't expect I will find a die for that size easily. May need to try a thread file.
Either way it would help me a bunch to be able to repair them!
Sent from my PH-1 using Tapatalk
Mine measures at 13.86mm, which makes it an M14 thread.
Not the most proper but could you not just crank on the nut a bit harder and force it to turn? The nut itself will flatten out those threads and still hold. Those threads don't look too badly damaged.
Thanks all. I was able to use a thread file that made short work of repairing the threads. It was $15 on amazon.
chasebradshaw
