Full Floater Conversion
I finished up the rear full floater axle, disc brake conversion. It took forever. Mostly, waiting on parts, and oh yeah....this little guy showed up
I now have 2 boys. The way I see it, I will need at least one more truck to pass down. I'll keep my eye out.
Also, as I tore into the truck I realized the problem was more involved than originally anticipated. The spider gear in the rear diff had also split
If you look inside the sleeve of splines, you can see the split. It knocked down the leading edge of the splines on the old axle. Fortunately it stayed intact and allowed me to get off the trail and home. The rear diff came from East Coast Gear Supply last year when I re-geared to 4:88's. I cannot say enough good things about that company and their employees. They were amazing in backing up their product, customer service and turnaround. So many other companies in the off road industry could learn volumes from ECGS! Thanks to Casey, [MENTION=51127]Dous[/MENTION] for literally shepherding my rear diff thru the process. Everybody can debate 4:88 vs 5.29, but there is no debate as to where to get them.
Drivetrain Specialists East Coast Gear Supply
I am loving the new full float disc setup. I used the Front Range Off Road kit and sourced various other chromoly parts from whoever had a sale or a coupon. I will eventually do a full writeup on this process because the kit has evolved and many writeups are outdated. I started with this writeup:
4x4Wire - Front Range Off Road Fabrication Full Floater
But it deviated right off the bat.
Thank You to [MENTION=67615]Dirtco[/MENTION] for helping with questions and guidance. He recommended I download the FSM for the '79-'85 trucks. This was a huge help as I hadn't even thought of the varying torque specs etc. He also helped me with some brake line questions.
This kit takes a while and has lots....I mean lots of parts, and steps. And you frequently need to ad-lib or improvise. This is probably why many of the write-ups fizzle out. Everybody just gets tired and wants to wrap up the project. It makes one appreciate the work that [MENTION=44220]BigFishAllDay[/MENTION] puts into his write-ups!
The foundation of the kit is the adapter which bolts to the housing via some large arp studs. Everything from your old drum setup can go in the scap pile. I enjoyed junking that stuff.
Here is the adapter bolted up
I painted everything except the sealing surface. Otherwise, the adapter will be exposed to the elements.
You can build up from here using junkyard parts, though I chose go to new. And new chromoly at that. Love em or hate em Trail-gear has many of the parts you will need.
Frontier 4x4 Off-Road Supply had the best prices on parts and a coupon. Chromoly spindle, hub, drive flange, ARP studs etc. Marlin Crawler provided all the seals. Again, thanks to Dirtco for that lead!
If you don't already have a seal driver, pick one up before this project. It gets used several times on each side with seals and bearing races:
Spindle and seals mounted up:
New Chromoly Moser Axles:
These were sexy! Almost hate to cover them up.
And the new FJ-60 Vented Rotor, and chromoly hub:
Sorry for the crappy late night pics. I basically work all day, play daddy day-care all evening, then play with the truck after everybody goes to bed. Sleep is over rated.
I went with new SW13 calipers. These are 4 piston calipers and were stock on front solid axle toyota trucks. A quick google search will show that all the import track racers (nissan, toy, honda etc) are wanting this caliper setup for its stopping power.
Also the trail-gear 6pin drive flange and cap, with new ARP studs.
It looks so good I almost hate to bolt the wheel on. But, at the same time, I can't wait to get it dirty.
The rear-end is basically all new. Diff, axles, hubs, spindles, brakes, etc, etc, etc. There were a lot of twist and turns in the process. I also added a manual proportioning valve next to the master cylinder to adjust the rear brakes. I will get some pics of that. As a result of ditching the ABS, my speedometer is acting up. Though, I've got a solution for it and will post up pics for that as well. Like so many before, I just became anxious to finish up and get back on the trail.
And a driveway poser since I was so excited to get it off the jackstands
Thanks for checkin' in!
