Um yea, except when you get sludge like I said servicing a s54 per spec with castrol tws.
I do love forum experts.
and that "per spec" is 15K is it not?
And does a S54 have a Bypass oil filter or during that 15K was the Mahle OX 187 filter changed at least once, or did they even use a OX187 and used a 68 instead? Also if the person owning this s54 actually waited until the "oil change light" comes on at around 15K or so, was that 15K done in under a year or was that oil subjected to 2+ years of short stop and go in cold weather running 10W60?
Is Castrol TWS even a real Group IV or V oil?
I assume if its a version that is made in germany that it probably is.
However aren't BMWs actually "required" to run 100% full synthetic oil, engines "designed" to run 100% fully synthetic oil? and that reason being that 100% fully synthetic oil is far superior oil.
BMW simply made a mistake in allowing even great oil to go too far in what is most likely a hot running engine that puts a severe hurting on an oils TBN.
Oil analysis in most of these S54 engines show that the oil is pretty much spent around 7000 miles, correct?
That means a regular petroleum oil in that engine would probably be spent in about 2000 miles, maybe even less.
Then thank you for "expertly" proving my point,
