Volant+TRD SC = 4500lb Jet :)
rolla_dink
So today the Volant intake (Thanks to Jason at Burtman) came into the shop and I decided that I'd put it on tonight because I'm an instant gratification type of person. BTW for anyone else with the SC, it fits just fine with no other modifications.
First thoughts:
1. Very easy install, about 30 minutes total to take off the OEM and slap on the Volant, that also includes the time to bypass the throttle-body coolant hoses (another side project of mine that needed to be done). The air-box screws were actually drilled correctly, my only beef is why don't they utilize all three holes for a solid attachment? I may drill that third hole myself.
2. not a fancy shiny metal intake as in my Injen CAI on my 1zz, however very heavy duty rigid plastic. Maybe better then the metal since the V8 creates so much more heat then my 4 banger every will.
3. typical the MAF screws aren't pre-drilled, which if your not a seasoned modder could pose problems, however since it is plastic I can see why they aren't predrilled.
4. easy to strip the MAF screws, so definitely tap and tighten by hand and only make sure that you seat the MAF with the supplied foam seal snug. My best advice is to tighten the screws enough so the "ring" portion of the MAF that goes into the intake tube is flush with the intake wall. Make sure to use the thicker supplied rubber-o-ring.
5. Use one of the supplied hoses to replace the vacuum hoses on the stock intake. Other then that it was really straightforwad. Supplied installation sheet sucks and if I didn't know how I'd be pretty pissed.
6. Startup was typical for an aftermarket intake, there was some idle "hunting" but it went away after 10 minutes of idling and 1 hour of driving. I'll give it another week to report back my final impressions.
So all I have left to install is the FTC1+AIC1-A2L and to the dyno tuners it goes...finally. I think what I'll do is put on the stock box and get a baseline, and then put on the volant for another baseline, and then tune it for maximum safe performance as I did my 1zzfe. I would go all max, but I'm looking to tune it once, maybe twice and leave it be.
For now it sounds like a jet engine in the front and it rumbles in the back. I really really love the 4Runner now. It is a complete joy to drive and sounds like a V8 truck should.
Thanks again to Jason Burtman for hooking me up!
I'd post more detailed pics, but I'm just not in the mood nor am I after a DIY. This is one of those if you can't figure it out, you shouldn't be doing it yourself.
T4RUSAF said:
you don't have any concerns with the CAI since TRD specifically says stock box only?
The only concern is the same as when I had the CAI on my corolla, leaning out under high boost especially in too high of a gear. I was able to correct the lean spots with just the AIC1 alone once I install the CAI on my 4-banger. I'm expecting the same results with the FTC1. I've found that the only reasons TRD CARB'ed with the stock box was for economic reasons since they probably didn't want to have to pay for testing with an aftermarket or provided true CAI.
Currently, even pre-Volant I would get occasionaly detonation right at boost under load in a high gear, once the tranny downshifted, the knock was gone. Anyway as long as I'm modest about my acceleration it's great. I've already contacted Split Sec for a dyno tune so I'll see what happens. I'd like to get it done before my Team NGC car show next week, that would be sick.
Nice pics!!! Yea, the volant does add a sweet power boost, while making the truck sound like it sound. Glad you like it! :)
http://www.burtmanindustries.com/zoomprod.php?id=4run_vol_47_4th_gen
WOW...what a rocketship!!
I can't wait to S/C my new Tundra...but it has plenty of power for now:beer:
Check out the Split Sec PSC1-001, that is what I used to dyno tune my AFR's it also as a MAF input for S/C'd applications as well.
Awesome ride!! :bigok:
since you dyno'ed your truck. im curious what your hp turns out to be with the sc and the volant.
i wish they sold and installed the sc on the newer v8
Ya, damn you and your S/C!!
J/K I am just jealous...
Jason B said:
How's it running?
Hey everyone. She's running good. Knocks a little if I boost and let off the gas and coast and boost again. I was having that issue prior to the Volant. Still working on getting her road tuned before the end of the month to properly fix the momentary lean out at the beginning of boost. I'm just wrapping up a few loose ends. All the wiring is in place for the FTC1, I just have to find a proper location for the O2 bung and am getting nowhere with my usually channels. I'm sure they are just busy.
This thing is just a beast. She should be able to run mid-low 14's the way she is now, but I want her to run safe and efficient hence the tune. This has been a long project for me due to waiting a loooong time for some critical parts. I will post results as soon as I get them and keep you all posted since it is nice to at least know the potential of our vehicle.
Note on the Volant differences, the truck from the dig takes off effortlessly and much much smoother...at first I thought I loss a little on the low end only to realize it was just not having to struggle to "breathe", the extra port in the box as well as the free flowing filter helps. Again when/if I dyno on the machine I will try my darnest to take the Volant off, dyno with the stock box and then with the Volant for all the non-believers. Having run aftermarket intakes on most of my vehicles and seeing the dyno charts before and after I recognize the benefits in smoother and more flow.
Anyway I'm targeting 330-350 rwhp and 375+ rwtq. With the S/C in theory with a 18% drivetrain loss on the 2WD I should have already be at ~290 rwhp and ~330 rwtq.
