VSCOFF TRAC ABS VSC keep showing up
Thank-you guys so much! I'm going to do this! [MENTION=59743]Darwalk[/MENTION] I'm going to follow the same procedure as the video posted by [MENTION=121505]namco916[/MENTION] but with pins 13 & 4, turn the ignition on and press the brakes with a foot seizure 8 times in 5 seconds. Please verify
How did this go? Did you figure anything out?
Thanks for following up man I really appreciate it. I haven't tried it yet but I have a paper clip prepared lol. The lights haven't come on yet since I unplugged the battery for a solid 30 min
Well that is a good thing then. Hope it stays off!
im glad you figured it out. i tried that method before the calibration and it would come back on everytime i went over a bump or up my driveway. disconneting the battery resets the ecu so im glad it worked. maybe your gas cap was loose, that causes the trac and vsc lights to turn on also.
I spoke too soon! They came back. This is going to be a nightmare to troubleshoot since its only sometimes. The only thing that changed significantly is the weather here in Houston. We got a hell of a cold front (for us at least). Although I was driving late last night when it was cold and no lights were on then.
That's what was happening to mine; mornings, only cold. Once I got the brake light switch replaced, it was gone.
man that sucks. i would now try the calibration and see if that works. if that doesn't work you could always try what darwalk did and replace brake light switch
I can't pull the codes because they show up intermittently, only while the engine is running :/
Once codes are thrown they are stored in the computer until they are reset or you disconnect the battery. Have you used a scan tool or taken it somewhere that they can pull the codes for you? Like [MENTION=118912]07Profiteer[/MENTION] my lights came on, pulled the codes, showed EVAP related, checked the gas cap and and realized it didn't matter how many times I clicked it, it felt like it was just pushed on. Got a new one and problem solved. I scan and reset all through the free Techstream download software and cheap Ebay purchased USB OBD-II. Worth the $20 just using it once and you can use it to program customer preference settings without having to take it to the stealership and pay their outrageous fee. Really need code numbers to do good trouble shooting.
Once codes are thrown they are stored in the computer until they are reset or you disconnect the battery. Have you used a scan tool or taken it somewhere that they can pull the codes for you? Like [MENTION=118912]07Profiteer[/MENTION] my lights came on, pulled the codes, showed EGR related, checked the gas cap and and realized it didn't matter how many times I clicked it, it felt like it was just pushed on. Got a new one and problem solved. I scan and reset all through the free Techstream download software and cheap Ebay purchased USB OBD-II. Worth the $20 just using it once and you can use it to program customer preference settings without having to take it to the stealership and pay their outrageous fee. Really need code numbers to do good trouble shooting.
Was not aware codes were stored in NVRAM. So Techstream is a free open source code analyzer? Do you have link's to what you used?
Crookedcat
