hamsandwiches
Ok so from what ive gathered, I will pull a body ECU, abs ecu, and all 4 wheel sensors if i can find them.
About to look through that diagnostic.
Thanks guys!
Thanks guys!
Durk, That instrument cluster test diagnostic is very thorough, but I'm almost positive the issue isnt the cluster because I already replaced that and it is giving the EXACT same issue now as the original cluster.
I see the truck body tests, I will look into those and also the wheel sensor tests
The ABS computer triggers the ABS light (make sure it comes on for a few seconds when the truck is started).Can't imagine that if thats the true data the engine ECU is receiving it wouldn't trigger a CEL or ABS light.
Back in the US, going to yard tomorrow in search of body ECM, etc
Not sure if I am crazy, but it seems to happen way less when its like 100 plus degrees outside.
After I crossed Connecticut and the outside temp was going up past 100, it did not do it for the next 350 miles.
Any thoughts given that info?
Engine speed comes from the engine ECU, speedo signal comes from the ABS computer (if ABS equipped, almost all are), fuel level comes from the fuel level sender.Not sure where the engine speed one is, but I know where the speedo and fuel sensor plugs are so I will try that next time it happens
