Wanted to change bulbs in my clear corners
kavalis
Would the Amber LED’s be the way to go? Looking on the Sylvania guide. Are they called the Parking light, Driving light or front Side Marker or Autolumination are they the Running Lights under the Headlight section? Would the LED’s be better than the Sylvania Blue tipped amber bulb thats in there now?
The Bulb is a 194 bulb check out my build thread below in my retrofit section to see them in action. If you plan on getting any HIDs or colored headlight then I would recommend getting a white LED bulb, the amber reflector still shows amber from the side while a nice white emmits from the front.
I'm looking for some switchbacks that will emit amber with the parking lights on, but a white when the headlights are on. Good luck!
LED all the way man
I got them from V-Leds
194’s? According to Sylvania guide Frt Side markers are 2825. :confused:
Front sidemarker
2825
2825ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
2825LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and
greater safety.
which one did you get?
yeah i think the Sylvania guide uses different numbers, I hate that guide, it makes finding bulbs a little troublesome sometimes. but if you notice on your link they are the same bulb. (194 is listed under the 2825) And i cant even find the bulb that i got from VLEDs, they must be out of stock or something. Im glad i got an extra set haha! anyway, it's this one here
002-21.jpg~original
003-18.jpg~original
Which one would you pick? Maybe the middle one w/3 chips?
Also what would be the best choice for 2825 License plate leds? You don’t want them too bright, right? :keyboard:
yeah, ive got the middle ones with the 5 or something bulbs in my licence plate lights and they are a perfect amount of light
003.jpg~original
as for your corners depending on what brightness you want like if you want a running light or something ive read good reviews on those $20 ones, but i think the 3 chip one would be fine too.
and if your interested these babies are excellent reverse lights (921)
250-1.jpg~original
003.jpg~original
250-1.jpg~original
Thanks man for steering me in the right direction.
My tails are the leds from Jason, so I don’t need anything there.
What about the domes, do I need the card or are the led bulbs enough? :beer:
Jason's LED tails came with led reverse lights too? but yeah man dont get the 1 watt 2 led bulbs, ive used those and they aren't that bright. VLEDs changed their site so im having trouble finding everything i've got before but i got one of those 2 piece lights where one is a circut board full of lights and the other is the adapter
oh and BTW its a 3175 31mm light for the domes and BA9's for the map lights
You don't need LEDs for the clear corners. I installed 194 PIAA Hyper Whites from Amazon for very cheap and they look great.
I had white before, then I changed to amber and they really look good because of the clear lens. Their not PIAA, I think Sylvania. Wanted to go all led if I can. :lookout:
