Wanting a little kick in the audio department
settytb
I have a 03 v6 sr5 without the jbl. So, I don't have the sub or the trim etc in the back. I've seen the threads on that and how people have upgraded it and I'm jealous of you people with it in there. However the trim panel and sub box are pretty spendy to get the oem parts. I really want something out of the way to keep the cargo as usable as possible. I've seen the custom box that goes over the wheel well but it's pretty huge and i would lose my little storage cubby. Not a huge deal but i think it's too big for my liking. I would just like to add an 8 or a 10 inch sub for more well rounded sound. Nothing window blowing or anything like that. Anyone try fitting a small sub under the passenger seat? I've seen people putting amps under there. I have manual seats so there shouldn't be much stuff under there. Just wondering about some small sub locations and what you guys have tried out there? Look forward to some pics. And I would have posted this in the audio section but our 4th gen nooks and crannies are way different than other gens.
I don't know if there'd be enough room under the passenger seat to fit a sub, unless it was super thin. I'd look for a sub that's made for the back seat of trucks so that you have one that's fairly thin....if that makes sense.
You can get away with hiding an amp under the seat but I'm skeptical about fitting a sub under one....
Sorry, you have to give up something. Sub(s) take room, and even the thinnest of subs still requires a box to go around it to seal it within a space (below the seat is impossible unless you want to go through your floor). Your best option I guess would be to try to find someone getting rid of the JBL sub and replace the sub in the box like projects here have done and put the amp up front under a seat, or squeezed in the back space too. This is "the best" option if you don't want to intrude at all into the general passenger space. I've taken the entire truck apart and there are no other available areas.
I guess if that doesn't work you'll have to live with no bass:sobbing:
I chose to go over the wheel well and glass a box, then put the amps where the little storage cubby is. It takes up some space but it was the best option I could accomplish on my own.
IMG_0098.jpg~original
If you look you will see zero space over what I've used for the amps and crossovers, and very little space for anything else. The box is far from perfect but isn't too bad.
IMG_2535.jpg~original
I still find I have space for 5 sets of golf cubs & I've packed the truck to the brim for road trips tons of times. The space I've taken up is minimal to the overall space available.
The shallowist sub I know if made by the manufacturer of the sub I have currently, here is the link.
That's a pretty sweet setup. Probably a little too big for my taste what is that like a 12? I was leaning more toward a 10, and possibly considering an 8...although a 10 would be ideal. I like how shallow that sub mounts that is way nice.
Thanks for the input on the passenger seat. That's a bummer. I'm thinking about some of these smaller self contained units so I could just run power/speaker wire and if need be unhook it quickly and pull it out. What do you guys think?
Infinity BassLink Powered subwoofer: 200 watts and a 10" sub at Crutchfield.com
Sound Ordnance™ B-8PT 120-watt compact powered subwoofer at Crutchfield.com
Something like that? And you could just mount it to the back of the 2nd row seat or maybe the trim panel itself (although not sure how sturdy that would be with a sub mounted to it.) Just some thoughts.
That's a clean "rear end" you've got there!!! :lmao: :cool:
settyb: I've seen some of the similar types of subs you're looking at, I know for a fact that the bazooka sub (it's all in one) in a tube but it doesn't pack much power. Especially if you're looking for something that has some more power to it for the noise factor.
Yes, it's a 12".
I have to say I chuckle when these little sub-compact sub-amp combos get brought up. The idea is good, you can remove them I guess (you would have to cap off the wires). But in the end they I feel they take up more usable space then the over the wheel well options, and cannot sound as good (I'll base this statement on manufacturers here).
I would go the JL Audio (Stealth box & 10w3 10") route myself if I was not able to build a subwoofer box. That is known to be good sounding, and could be removed too.
Here is another solution that seems to fit your application requirements:
http://www.amazon.com/Pyle-PLBASS8-..._1?s=automotive&ie=UTF8&qid=1329145655&sr=1-1
I came across this years ago and was always curious to how good they actually work. Seems to have good reviews though. There are plenty of this style item at Amazon. All inexpensive and low profile like you're looking for. Hope this helps. Let us know how it turns out if you decide to go this route.
patnewton
