I modified my modified FJ shift knob.
put in some HIDs in the lows an some PNP LEds in the fogs
the low beam kit was a generic kit Nothing directly plugged into the OEM connections. The whole install for 3 hours +-. I had a all the parts and shrink wrap tape and connectors.
luckily im really good and soldering and splicing. THe outcome was clean and the difference is great. I may aim them down a tad if I start getting flashed.
cut off goodly weather tight connections to swueexe the OEM lamp in the factory cover location.
All fits tight
IMG_2144_zps28b5845e.jpg~original
IMG_2142_zps9b6c02d8.jpg~original
my shrink wrap and wire tie hob
IMG_2153_zps9a2829a7.jpg~original
all hidden
IMG_2152_zps7ed44aa1.jpg~original
mounting on fender
IMG_2151_zpsefac99b1.jpg~original
IMG_2149_zps772df6ca.jpg~original
piss yellow stock
IMG_2148_zps554691e5.jpg~original
let there be light!! 4300k
IMG_2147_zpscf9d5812.jpg~original
IMG_2146_zps7da3abce.jpg~original
IMG_2145_zps1c139967.jpg~original
Today I mounted the gas can brackets I made for my rack this weekend. They work great, hopefully the cans work as well...
Pictures in my build thread (Link in Sig)
Going to try them out this weekend or next.
I attempted to install my Budbuilt Hidden Winch mount. It was a little slow going (no freakin' instructions!). It really took a turn for the worse when I over -torqued the nuts holding the aluminum bumper on (had it set to 100ft-lbs....seemed reasonable for a bumper) and sheared-off a couple of the bolts. Had to drill the bolts out and weld new ones on. Now I'm not even sure it's strong enough to use the winch :frusty:
Ah man bUUUUmmer :eek:
Not that it is really any help now but:
TORQUE SPECIFICATIONS
Front Bumper -
Received my Husky liners...now I just need a 4runner to go with them. Current dealer estimate is this Wednesday :dance:
while not exactly in my 4R.. I received my jetfoil flash in the mail today!
A few members have had good things to say about it, such as [MENTION=65614]Antman[/MENTION] and [MENTION=66300]Intruder[/MENTION].
Can't wait to try it out.. Where do you buy the gas cartridges for tis thing?!!!
You'll love it!
You can get the fuel at Walmart, Dicks, Bass Pro, etc.
The gas canisters also come in two sizes, the small is perfect for backpacking, while the large is handy if you are car camping or anything else. Those little stoves are outstanding, I've taken mine snow camping at high altitudes a number of times and it does such a good job.
Front Bumper -
Wow. I feel like an idiot. I'll admit. This is the first mod I've done where I felt I was over my head. I'm no mechanic, but I'm pretty good at following instructions....I should have known better than to even try it. I definitely would not do his again. Taking it to a body shop tomorrow to have the pros fix my screw-up.
Don't beat yourself up, I was surprised to read your mishap. I was curious too, which is why I looked it up. I thought it was odd and it actually makes me wonder if it is indeed a good idea to bolt a winch on that thing after seeing this. I know straight pull strength is much greater than shear but I am no engineer. [MENTION=66316]1engineer[/MENTION]
Which brings me too and even more critical question, has this thing (budbuilt hidden winch plate) been seriously tested at all? I only assumed it had been to some extent because of the price, that maybe this thing is rated. I see people bolt them on has anyone done any serious pulling with it? I am definitely now having second thoughts.
Also. Played around with the rollers and can't quite get them to fit through the lower grill without some trimming. It's still not fitting quite right, but I had to call it a day after about 7hrs of fumbling. INSTRUCTIONS SURE WOULD BE NICE, BUD!
Front Bumper -
"...It really took a turn for the worse when I over -torqued the nuts holding the aluminum bumper on (had it set to 100ft-lbs....seemed reasonable for a bumper) and sheared-off a couple of the bolts."
Sorry man, I laughed when I read this because you are NOT alone assuming torque spec should be higher for something like this. I did a write up here http://www.toyota-4runner.org/5th-gen-t4rs/95630-broken-stretched-lug-stud-issue-solved.html (post 11 starts) about torque and lug nuts but it applies to all mechanical fasteners.
You didn't happen to squirt some WD40 on those bolts before you tightened them did you? If you did shame, shame! Just kidding.
[MENTION=8206]harper7[/MENTION] is running the hidden mount and he has probably used it. He would be a great judge on strength so you guys should pm him to ask. Anyway, if you want to learn a little about torque read the link and enjoy!
Find a tree up hill from the truck, attach the line and winch away. You will know soon enough if it's strong enough. Better to find out now then stuck in the middle of nowhere.
When you reel on the line it should be under load anyways.
I use it to clean the crap off/out of those nifty little electrical connectors on the back of my brakes. Is that bad? Usually a squirt or three in pockets where dirt tends to build up seems to make it easier to clean off. *strictly unscientifically unproven
Thanks for the torque link :)
Hmmm, LOL why in the f##k should I or anyone else pay money to do R&D on something? :doh: Like I want to tear the front end off because of a failure. That makes no sense what-so-ever. Just asking if anyone has done hard pulls on it or if it was tested under heavy loads. That's all.
If, on the other hand, I was given a unit with the express intent to test it then that is a different story. :)
Of course, you should always spool under enough load that you won't bury your line under bottom layers when you do winch under heavy load. Winching 101. What does this have to do with pulling the front end off of the truck? :D
Aren't most aftermarket steel bumpers also bolted on at the same bolts as the BB winch plate? Which would me it's roughly about the same strength as a winch mounted on a steel bumper?
Or do the steel bumpers have additional reinforcements to the frame? I am not sure, I never really looked into installing one before.
One thing that does come to mind is I think the CURT front receiver is rated at ~9000 lbs line pull and they bolt to a few of the same bolts as the BB plate. BUT the front receiver also ties into the front recovery hooks, so that's probably distributing the forces :noidea:
Here's their instruction where I read it this: https://www.curtmfg.com/masterlibrary/31367/installsheet/CM_31367_INS.PDF
It was a nice day today so I had time to wash my baby. Just did a quick wash at a wash bay to really see where the paint needs correcting. A lot of claying will be needed now.
Jhunt
