Looks good Mike!! Just curious which mounting bar did you use for the LP6’s. Also did you wire up to a push button switch. That what I did for my Bajadesigns led light bar. I was going this way then decided to do the light bar. Do you think the LP6’s fit good or do you think you should have went with the LP4’s? Thanks.
Thanks! I used the N-Fab LBM bumper mount. For some reason it didn't inside the grill properly so I used the side brackets as the base mount for the flat mount. I some how still got it to work?
I'm using the wiring harness kit that BD made specifically for the LP6/LP9. The switch doesn't actually fit flush with any of the empty slots. It sticks out a bit but fits enough where it doesn't fall out. I'm still trying to find a button/toggle switch that I can switch it out with BD switch.
The LP6 is actually quite large. Top row of lights is actually a little blocked by the grill. I think the LP4's would've worked and fit better but I opted to go with the LP6's because I could use the BD wiring harness instead of getting another option.
But I'm still very satisfied with the look and size.
2021 Off Road Premium
Just picked her up today MGM. Stock for now
Going to list my 2015 MGM Sr5 tomorrow.
47,800 mi. with some nice mods.
It was a good day
My push button switch is from on board switch. You should be able to wire it up just like it did. They fit perfectly for the blank switch spot. I have a picture posted on the one post. I have the same mount. Still did not sell it yet. Yeah I did not like the look with the BD switch so I put the push button in. Hope this helps.
It took 2 years, but finally got my ICS installed along with the cell phone mount :rolleyes:
ARB Air Compressor Wired To Switch Pros
Cut out 60% of the ARB harness first. Even then it was a hassle. They really need to modularize that thing a bit more.
Finally installed the ARB rear diff breather kit after it sat on a shelf for a few months.
I really think ARB should switch to using fuel line or something similar as the plastic tubing they provide is a PITA to uncoil and run without kinking.
Decided to run the breather nozzle right up next to the airbox in the engine bay.
built a bed platform. Front 1' flips up to allow for storage behind the front seats, or if I need to move the front seats back.
also installed a 2.5" Daystar front spacer lift and 275/70/17 General Grabber ATX's. I had previously done a BMC, fender liner relocate, and fender delete to fit the SCS -38 wheels. had to trim the front plastics a bit more after the lift.
going to get it aligned today. it's pretty close to level right now, but I have a feeling I will end up putting in .5 or 1" rear spacers, as I prefer a slight front rake.
....The Year In Review?
...Howdy, Pardners!...:cowboy:
...It has been many months since I posted anything new...:noidea:
...So what I did today was post a new video of the year 2020...:ranger:
...OK...as a HELLUVA lot went down last year!..:yield:
...to be a bit more specific....:noidea:
...I posted a video of what I did and where I went with my 4Runner...:clap2:
...As many long-time readers may know...I do not rock-crawl...
...I do not overland...I do not take cross-country road-trips...
...I am a Nature-Photographer living in SW Montana....:cowboy:
...So, I use my 4Runner to take me out and get me back from cool places where I can setup and take photos, video, and time-lapses...:director:
...I have outfitted the inside with a large bolted-down lockable box for my gear, and a sleeping platform...recovery-gear, etc...and drive off on ranch roads and national-forest roads...and any other dirt roads that take me to scenic places...
...I have a brother who lives in Mesa, AZ..who is also a Nature-Photographer...and we share videos back-n-forth of our adventures...
...SOooo..altho there will be no actual footage of my beloved 4Runner in the following video....it helped me produce this piece...and I could NOT have been able to do it without my 4Runner!...:thumb3:
...Below, here is the year 2020 in review..or at least...the Best parts!...
https://www.youtube.com/watch?v=zaPJur9IOWo&feature=youtu.be
...Hope Y'all Enjoy it!.......Muchos-Thanks!......Cheers!... :cheers:... :cowboy:
Everybody and their mama's in the PNW playing in the snow. Decided to do something different and hit up the dunes in Eastern WA.
things I've done recently
i am testing morimotos new LED on my 4runner...its ok not impressed coming off HIDs there's a big rectangle of light in front of the truck and o peripheral lighting..the morimoto fog lights filled that in...HIDs had a wide swath of light in front of the truck LED does not. going back to HID.
added the bajarack rear ladder
it was a pain in the ass to install use a rather strap toward the inside of the ladder to bring it down. its now tight and not going anywhere
bajarack and arb parts that showed up also
in but not installed yet
bajarack awning mount and shovel and axe mount
arb awning with walls and floor and wind wall
What is the size of the bolt and type nut used for the terminal block plastic cover to mount too?
[MENTION=268462]mtntrekker[/MENTION] ...
1) Cut some plexiglass to fit. Had some of this lying around from something else.
2) 10/32 stainless bolts. Can't remember what length - I have a lot lying around.
3) Aluminum Standoff 3/8 OD x 10-32 Thread from aluminumspacers.com ... I bought 7/16 since that got it about the same height as the black plastic.
4) Stainless knurled head nut.
Besides giving a bit of protection from the weather, I think it finishes it off well and looks like it fits in with the fuse block and bus bar covers.
Thank you for the great information. I think it looks good too.
Jhunt
