Now that he has the off road bug :boink:
Where in PA and why didn't you call me? We like peaches:p
New Park PA- Maple Lawn Farms. I woulda' called you but the Beefy Peaches aren't in season yet.
No, it never gets old my friend!
Well, I'm surprised they even let you cross the border :hatsoff:
Next time, no call - no peaches!
Cheers!
Had my sunroof tinted - 35% Llumar High Performance Series - Just to keep the rig a bit cooler when it sits outside in the parking lot all day.
Seems to help quite a bit!!!
really? more so that just closing the shade? hmmm, might have to try that
I was under the impression that tinting the sunroof can cause it to explode/shatter for no apparent reason. I can't remember if this was something the tint shop told me or if I read it online. It might be one of those myths.... Like Blinker Fluid.
apparently there are certain types of tint that can be used. Llumar happens to be one of them
I do not believe it is a myth. I have tinted two sunroofs here in AZ, and both have blown to pieces. Thankfully, I was not in the vehicle at the time for either of them.
has something to do with being a metal based tint.... the cheapo black tint (used for looks) doesn't dissipate heat sufficiently
I WANTED TO GO PLAY :D MAWHAHAHA
Hiked up to Holy Jim trail which ends at a water fall, more like a spring right now:
Where's that at?
Did a ton of research about this sunroof shattering stuff... I double and triple checked with my tinter, two other local tinter's, and some online resources... kinda researched the $hit out of this and here's what I found in case anyone else out there is interested in getting their sunroof tinted.
- The sunroof shattering "myth" started in the 80's or so.
- Dual pane sunroofs such as those found on Porche's etc, have had problems with this due to the heat reflecting off the tint of the bottom pane and being trapped in the airspace between the two panes and causing an "explosion"... supposedly....
- Older tint, especially the near "limo" tints back in the 80s had poor heat reflection and had more heat absorption qualities causing a massive buildup of heat in the sunroof.
Everyone I have spoke to said they will not tint any vehicle with a dual pane sunroof, but they have no problem tinting single pane roofs on modern cars. They all said they use reflective type tints to maximize heat reflection, and minimize absorption. All three tinters have tinted hundreds without an issue.
I'm pretty confident I shouldn't have problem so I will be the guinea pig on this one. :banana:
Seeing as I am getting my windows tinted on Monday, Should I ask for a reflective tint on the sunroof? Lumar is a good brand so I have heard, but I'd like to get some heat reflection on the sunroof seeing as I live in Vegas and it's hotter than a camel crotch in a sandstorm.
need some help
Hey guys i have a 95 4 runner best car i ever had....im having problem with the brakes...i have brakes to stop but i have to press the m all the way down... Its kind of soft pedal...I'm thinking its the booster?....any suggestions ? Thanks
wrong thread.. but it sounds like you've got a brake fluid leak somewhere or your brake booster went bad
NVBASSJUNKIE
