Installed this 100 watt Renogy solar panel.
Power is stored in a 300 watt rechargable battery pack. Running a fridge I picked up on Amazon. Actually everything came from Amazon.
Sent from my iPhone using Tapatalk Pro
Is this going to be pretty self sufficient? How many days could you run that without recharging the pack?
I would like to avoid a dual battery system if at all possible. Keep things simple.
Getting ready for the beach. Designed a bracket for my treds to be offset so i can fit 10x10 tent inbetween the treds and the roof top box. Had a local shop weld it and drill the plate.
Sent from my SM-G973U using Tapatalk
I'm actually returning this battery pack. It will not run the fridge overnight. A friend of mine has the same set up but has a Goal Zero 400 which has almost 400 run hours. It will run his for 10 hours.
To be clear as long as the panel has sun it charges any battery pack and will keep the fridge running.
I also don't want the dual battery set up. I just don't want to tie into the Runners electrical system. I would rather keep in stand alone.
A little after dark action on the 4Runner:
- applied a set of decals to the C pillars of the truck (its nick name is Ursa Major or "Big Bear")
- test fitted some Yakima traction board mounts, I think I'll go with these in favor of the Rhino rack mounts because these lay flat on the rack which means better clearance and airflow.
- started stripping the bed liner off my skid plate
If anyone asks what is my number one "oops I shouldn't have done that" modification having the skid plates bed linered is it. While the bed liner does give better protection against rock chips on the road it doesn't do squat when you're sliding the vehicle over a rock. Then it peels back like an orange. Also it's f'n heavy.
Therefore I am removing it from the bottom of the plates and will be painting them a pleasant shade of orange, specifically Allis-Chalmers orange tractor paint because reasons!
Then when it chips or scratches I'll just brush on some more to cover it up.
Going to need pics of the orange skids please.
Thank you good sir! I'm taking a screenshot of this for when I'm ready to upgrade from ice.
Good to know about the Amazon Battery... I need to start pricing up a solar setup for next year's budget. Gotta get more trips in where I will be remote without a dual battery.
...also don't want to make things too complicated.
Finished my cargo divider net. It was alot more work than i thought (109 box stiches...) but turned out how i wanted. I made my own c pillar mounts so its more of an L shape than a straight line from the seat bracket to the rear hook.
You need at least one more table and one more thermos...
:biggrin2:
Removed the XREAS from my 2015 limited and installed OME/Bilstein lift with SPC UCA's. Amazing ride quality. One of the best mods I have done
I am planning to mount a solar panel on my rack. From your pictures, I can't tell if you mounted it to the front or rear of the vehicle. I'm wondering if there's any additional noise where the panel is installed?
Anyone else think wireless charging is impossibly great and that it's unfortunate our dinosaurs don't have this tech? Yeah, me too! So I did something about it...
I’ve been in the center console a bunch of times and noticed there’s about 1/4” of room on the bottom of the lowest cubby. More than enough space for a wireless coil pad. I found a three coil setup on Amazon and immediately took it apart:
A small notch in the web at the front of the cubby and it slipped right in:
A few pieces of 3M VHB and it was pretty securely anchored:
One dissected 12v USB port later:
And then a little hocus pocus:
And lé voila:
It doesn’t fast charge, but I have USBs all over the car if I need more power. It’s so nice to just drop the phone into the perfectly sized console and have wireless everything. I'll post a picture of it charging when I get home and can have a neighbor get a shot.
Please do a write up of this so I can make one that quick charges.
