Installed my Denso radiator this morning
Decided to replace my coolant but didn't have enough on hand. Skipped new hoses for now; I'll do those when I do the coolant.
How y'all fee about Zertec?
Sent from my Nexus 5X using Tapatalk
Zerex Asian formula is the next best thing to Toyota red, don't be afraid to use it. I used it on my last fluid change when I was replacing my OEM thermostat. Don't skimp on thermostat, sensors, and LBJ's -only OEM for those. Pretty much everything else has a quality aftermarket alternative.
Just called my local dealer, Toyota Red after discount is $30 a gal out the door.
Zerex Asian 50/50 is $16 plus tax
Seems a wash since I'd dilute the Red 50% with distilled water. Amirite?
You can get Zerex from Walmart for $12. Usually more convenient because you're already there for something else vs an extra trip to the dealer.
Sent from my SM-G900V using Tapatalk
There's a Walmart up the street from my office. I can check at lunch today.
Thanks!
Thanks!
https://www.walmart.com/ip/Valvoline-Asian-Vehicle-Antifreeze-with-Zerex-Pre-Mix-1-gal/49660461
I researched this a few months ago and found that there is no (or very little) difference between 'Valvoline w/ Zerex' and 'Zerex by valvoline'.
Not sure the reason for the different containers, but it's all Zerex, and it's all made by Valvoline.
It's even 'Toyota Red/Pink'.
I got mine from O'Reillys on sale but I remember there was a significant price difference and it was a little more convenient for me. My local parts dept at Toyota Carlsbad has about the worst dealership parts prices I've run across and they won't price match Camelback Toyota. They'll only price match local dealerships (that are not much cheaper) so I try NOT to give them my business anyways. Sounds like a wash to me for you either way.
My local Carquest carries Toyota Red. That's where I get mine. Don't remember the cost, but it's not that expensive.
Sent from my SM-G920I using Tapatalk
Rear body mounts
I love those color combinations you are rocking! Have you swapped out the rear body mound for Sonoran Steel body mounts? Most people running 4X Innovations rear swing out swap them out to eliminate rear flex with that swing out.
Rear 4Runner Polyurethane Body Mounts (Pair) - $75.00 : Sonoran Steel, Sonoran Steel Custom Metal Fabrication L.L.C. Custom Toyota Truck Parts
Looking sharp!
Thanks man! I did a 4 crawler 1/2" body lift but haven't done the rear mounts. No more pinch weld contact plus a little better clearance upfront
I've been told different things in regards to mixing and what not. I looked at our FSM and it suggests to not mix it on CO-23 (is the reference page). It costs me a little more but I did all as recommended. I don't recall what our in vehicle manual suggests, but I have followed my FSM on everything and haven't had a problem yet :).
Checked rad before driving to lunch. Coolant level is about 1/8" above the fins, overflow is at the hot level, and there was this dried leak on the top tank.
Loose cap? Replace?
Cap is a cheap test/check. How many miles?
I can tell you my cap doesn't look like yours, haha.
Lol
Its the cap that came with my timing belt kit. Used to seal fine on my previous rad, it was on there for less than a year.
I'd have to lookup the mileage. I'm at 239,157 rn, so probably around 40K miles ago.
Lol
Dump the cheap aftermarket radiator cap and pick up an OEM Toyota cap.
Philthyphilthy
