Status
Not open for further replies.
Got all retro
Went all retro on my brake system. LOL. 76 Blazer MC with a 1 1/8 piston. Waiting on parts from summit auto to bleed the system. Had to slightly modify mounting holes, thickness of bracket, and make a new push rod for the booster since the stock one couldn't be shortened enough.
more to follow.
josh:toilet:
mc.jpg~original
more to follow.
josh:toilet:
mc.jpg~original
we are gonna need a write up on this one :drummer:
I didn't even know there was a light in the glove box. You learn something new every day.
That means your light has been out as long as mine, if not longer. I had a feeling there was one there, but had to look for it to make sure there was one there.
Have been contemplating wether or not I want to take the time to buff and polish the paint on the car. Decided to to a test with the hood to see if the results are worth it.
Left side is before, right side is after
20120312_1829361.jpg~original
20120312_1829471.jpg~original
Started with a heavy compound and a wool pad, then a lighter polish and soft pad. Even without sealant or wax the results are still pretty good. Probably 90% correction. Got all the swirls and fine scratches out. Still some chips and heavier scratches remaining but they would require wet sanding.
Also touched up my tailgate where it was rusting from rubbing on the tail light guards (now removed). Getting much better with touchup paint. Looks like it never happened. Sanded it down, primered it, then built up some touch up paint on the spot and wet sanded it smooth.
Forgot to take before and after pics. :ybrick:
Installed the Airaid Jr. kit that I got from Jason at Burtman Industries (thanks Jason!). Pretty cake install especially if you have the supercharger in place already. All the hoses are in the right place and no extensions or splices needed.
Before:
IMG_0344.jpg~original
After:
IMG_0345.jpg~original
IMG_0346.jpg~original
Really cleans up the passengers side of the engine compartment. Also did the "big hole in the airbox" mod since I had it out. No deckplate at this time.
And cleaned the throttle body as well as I could and blew out the mass air sensor.
Not bad for the remaining daylight after I got home from work. I love daylight savings time!
Oh yea, also adjusted the headlights.
oh boy did i get in over my head on this one lol! soon to be done, I just gotta think it out a bit. The PIAA's are gonna take some work to get in there, and i still need to paint a little, but so far this is what i got
bleh025.jpg~original
bleh023.jpg~original
Nice work on the switch back LED's man! I'm working on a little something as well.... stay tuned to my build thread, if you are interested!
Bought two of these at TSC for 33 bucks total. Figured if I'm going to take my stocker out to Wishbone Ranch this weekend, I better get ready to be pulled out of a situation....
2cfc0ef3.jpg~original
And I took off the chrome strips that were on my fenders when I got the truck and promptly washed it. Dang my paint's dulling out.....
936024cc.jpg~original
To tell you the truth, I've never really thought anything of it. I can't remember why, but we never thought of using the stock grommet. The hole was drilled years ago, and hasn't caused any issue, and unless I'm missing something, what could be so bad about doing so??
Water won't get in, anymore than it would through the heater vents, or other small cracks and such.....
Again, maybe I'm missing something that you know??
If C.O.B says it's do-able through the grommet, than it must be. He's had his entire truck taken apart at one time or another, so he would know! :)
Good luck on fixing your setup pdx650!
I've run all my wire thru that rubber gromet. Using a wire coat hanger to fish it thru works very well and once you do it you'll wonder why you didn't do it earlier.
Status
tyler_ross
