One little stomp and he's problem free. I hate when they're in my truck.
I finally found it this morning hiding in the driver's window defrost vent. I tried to get it but it ran into the vent. Got in after work and it was on the door, between the door crease and the dash. Splat
Any advice on getting the rear shocks off the top mount??
I know asked Jake, but I figured I'd chime in. I left the bottom of the shock on the mount, unbolted the top of the shock, then unbolted the swaybar endlink.
The weight of the axle should pull the top of the shock out of the mount. That's what we had to do on A_Hul's truck because his was stuck in there.
It looks like there's no room up top to get tools up there , is it as bad as I'm thinking it's going to be?
You can get a wrench in there without cutting it, I've done it several times. It's MUCH easier if you have a ratcheting wrench, but there's no way to get a regular ratchet up there without trimming some body metal out of the way.
If the shock shaft rotates you can grab it with a pair of vice grips.
Or doing a body lift before the suspension
I have a full set of racheting wrenches, so that's what my plan was, but I just wanted to ask if anyone had tried that. My plan is to go at it with the racheting wrenches and some visegrips to hold it if it spins.
Here's to looking forward to taking off a high mileage suspension! :thumb:
EDIT: just saw matt suggested the vise grips.
You should be fine then as long as your bolts aren't rusted to hell like mine. But hey at least Austin and I didn't have to cut through my front shock body like [MENTION=72620]A_HuL[/MENTION] and [MENTION=50591]gaterose[/MENTION]
Does the BL give enough room to use a ratchet? I've only done it on a 1/2" BL and there still wasn't enough room for a ratchet.
You shouldn't have any trouble. I'd try the vise grips (or 7 or 8mm(?)) on little nub on top before grabbing the shaft with it. If you've got ratcheting wrenches it shouldn't be a big deal though, but it might be a pita to hold a wrench on top and loosen the nut with a regular wrench.
Good luck with install!
This is true. And I'm thinking they're not going to be rusted on too bad. Cause I think the previous owner had the rear shocks replaced with some monroe reflex shocks a few years back.
Thanks Matt and thanks Jake!!
I pushed out my bushings today and I'm waiting for my bushings to come in early next week. Thinking about taking a day off next week and catch up on mods.
Pictures will be posted.
Yep, x2 on this. I used a regular crescent wrench and a pair of pliers, no issues. Soak all your bolts in PB asap...
Lol, we cut through the shaft, twice actually, not the body! Body prolly would've been easier... but messier.
