I was just answering your question on what UCA's they were. Never tried them. Wouldn't mind trying them if I had a need/desire to go taller. Looks like the ball joints would be easy to service.
Oh! Sorry, thanks for posting the link though.
[MENTION=98763]80jay[/MENTION] how do you like those UCA's so far?
Drove to the beach to try and catch some shots of this meteor shower. Saw three in an hour, got distracted and took some truck shots
I was pulling wiring from two old lights yesterday, so I was playing with the battery a bit.
Got in the car today and none of the windows were working. Had a massive panic attack as I was hitting each switch and figured I had cut the wrong wire or something. Then I pressed the window unlock button..... :frusty:
Hit the ripe young age of 66k
Are you that old lady the just drives her 2005 SR5 V8 Satoshi grill, Tacoma TRD Bilstein Struts, FJ Cruiser front coils, front Daystar 1" Spacer (2" lift). ToyTec Superflex 2.0 2" rear coils, Bilstein 5100 rear shocks. Cooper Discoverer ST Maxx 255/80/17, 1.25" wheel spacers. A bunch of lights to church and the grocery store? Wow that is low tires, I am double that mileage and I think my mileage is lower.
No the previous owner was. Bought in 2013 with 43k, so they were averaging maybe 5k a year. I only have a 2.5 mile commute so that does help, but my truck is our road trip vehicle so that's really whats bringing my mileage closer to 10k a year.
Nope. That would be me.........
'12 trail wheels and '15 rubicon tires installedd
Almost done with the new grill. It was exciting at first....until day 5 came and the frustration kicked in while trying to make it fit...a coat of black paint is next
I'd like to see more pictures including the inside. What kind of materials did you use?
Driving from Chicago to seattle. Made it from Chicago to the badlands south Dakota in one day with enough time to drive around and actually see the park.
Today we spent a little more time in the badlands and then drove to Mt rushmore and the black Hills before heading through bighorn national forest to cody wyoming for the night.
Truck is running great. Gas mileage was solid until I hit the south Dakota 80mph speed limits and the mountains.
Changed it up a little tonight... swapped two 4" lights for one 32" light and had to trim the grille a little but I think it turned out pretty good. Will see in the morning when there's more light! And the bar is super bright, even with the plate covering some of it. I don't like front plates but I've been stopped a few times in the past so I keep one up front now because I don't like getting pulled over.
With the help of my bro and fellow board member [MENTION=91304]28.[/MENTION], we changed out both the front and rear diff fluid, plus the transfer case fluid
did some more work on my light mount after work. drilled the two center holes for my light mount extension
20150327_193019_zpsl6wgvuhh.jpg~original
marked center holes
20150803_161805_zpsiqdis1lj.jpg~original
drilled and test fit. mounting the center lights tomorrow to see where the two outer light go then trim the ends
20150813_234609_zpsyvo3ciie.jpg~original
Do you have any pics of how you mounted this? I want to do this exact mod, and fortunately in my state there is no front license plate! :thumb:
I ended up building my own frame from angle iron and flat stock I got from work and used stainless steel mesh from a friend.
The bottom piece is angle iron with a tab welded to it to bolt the hood latch to.
The rest is flat stock. The frame and screen are bolted together and connect to 6 of the original bolt locations. I had to make plates for the side bolts to reinforce the mounting points. I'm still in the process of making some nice aluminium spacers to replace the stack of washers that are there now. I also need to fix the hood latch mechanism since the hood closed on it and crushed it while I was trying to line up the bolts holes.
