I'm a new member i got my 4runner about 4 months ago and love it its a 1999 limited with 249k miles and runs like a top even though its a salvage title we paid $2000 for it done the oil and sparks plus filters but what are the best things to do and what are some easy bigginner mods for someone like me?
Change all fluids
-transmission
-axles
-transfer case
-flush power steering
-flush brakes
-flush coolant
Search "Strawberry milk shake"
-either replace the radiator or run a transmission cooler instead of going through the radiator (search "transmission cooler")
-replace lower ball joints
-timing belt and pump
-inspect belts and replace if cracked
-inspect brake lines and replace if cracked.
-grease drive shafts
Visually look for any sort of leaks.
Replace worn out hoses in the engine bay.
Inspect for rust on the rear axle and frame. Make sure there isn't too much.
Pull all the tires and pull your rear drums and see how much pad you have left. I personally would upgrade your front brakes with Tundra brakes. Search "Tundra brake upgrade".
I did all of this plus more, but I was picky about how it drove so I replaced sway bars, rack bushings, inner and outer tie rods etc.. There's tons more, but you want to get the main things taken care of.
Once you get all of that out of the way then assess how much you can afford for mods. There's all kinds of things you can do for next to nothing and then you can really mod it out with lift, lockers, tires, armor.. Though it depends on what you are using it for.
Welcome to the club!
