I my self would hesitate using the OEM filter element from Toyota in the newer 4runners unless you plan on changing the oil after 7,500 max miles. I believe that these paper elements were not designed to last for the 10,000-mile oil intervals and could cause engine damage if used as instructed in the owner’s manual. The filter fitment guide shows that these paper elements are also used in the 2009 4runner which used conventional oil with recommended 5K oil and filter change. I do believe that this element is still being made the same way and has not been upgraded with synthetic fibers to be used in the new gen 4runners with 10K oil change schedules that are now using synthetic oils. If you want your 4runner to last buy one of the after market filters designed to be used with synthetic oils. Why would the manufacturer care what happens to you ride after the warranty runs out?
