FiReBReTHa
Confidence in the 5160's dropped quite a bit....
90 fraking days....
I've had burger king tacos with longer warranties than that.
90 fraking days....
oh well on the 90 day warranty, i've had around 16 months of no issues with 6112s/5160s with stock rear springs, and then around 9 months with 6112s/5160s with SAW 1.5" coils (which for the record added around 2-2.5" of lift in the rear). When i added the SAW coils i moved the circlip on the 6112s up to the 4th groove when counting from the bottom up.
Currently im looking to beef up my front coils, is anybody running OME coils on the 6112s? I have added a SSS hybrid bumper (~75lbs), a superwinch with synthetic line (~60lbs), full shrockworks skids (adding an estimated 45ish lbs directly to the front springs) and i have more weight going up front with another battery planned and a ARB dual compressor. I want to buy a front spring to fit around my 6112s that will give me 2.5ish inches of lift and be done with it for a WHILE.
current weight estimate: 180lbs
planned weight additions: 90lbs
50lbs battery & 20lbs compressor, air tank, & mount and i'm adding 20lbs of fudge room in here
i can definitely tell after i put the winch and skids on that there is some drooping in the front and i want to gain some lift back in the front. Looking for suggestions on the spring i need to work for me, as well as what groove does my circlip need to be in when i put the spring on to get me the desired lift back. because i DO NOT want to have to pull out the shock once its reinstalled just to change the circlip setting. at that rate i might as well get an adjustable front coilover via spanner wrench and save myself the trouble...
any suggestions?
Also for the record this is a 41 page thread, i did search for "5th gen 6112 OME coil" and did not find what i was looking for. :hippie:
Any recommendation on where to get a single shock replace? Since Bilstein is not going to cover under warranty, I was hoping maybe they consider providing a discount or at cost/invoice to help out the situation as 90 days is pretty lame. It's either I replace 1 5160 or 2 5100s for about the same price. What u guys think?
alright did i show my newb-ness??? since i posted this ive been trying to determine if the OME coils will even fit the 6112... cant find any specs on the OME coil ID...
:help:
also does anyone know which groove the circlip should be on if i move to an OME 886? A guy in my area is selling the OME 886 from a taco for dirt cheap and i want to try to get my ducks in a row on what my plan should be or if these will even work on my ride.
:help: x2
sheesh im having a tough day finding the information i need. please assist oh great and wise (and sometimes wise ass) forum members.
:help:
:help: x2
OME front springs will not work with the 6112 as they are not coilover springs. The 6112 are 14"x3"ID springs and likely 550-600LB weight. I have a set of King 650LB up for grabs which are ideal for additional weight of a front bumper if you want. They are the same as the 6112 springs just with a bump in load rating.
These might show a little better but still have rake similar to factory. I'm at the 3rd ring on front and 1.5 spacers in rear.
OK, there is definitely something going on here relating to a design flaw. I think you are the 6th person that has reported some kind of a leaking problem on this forum with the 6112s.
[MENTION=107460]Magnetic4R[/MENTION] what did you end up doing with your leaking shock? Did you replace w/ something else?
