Where can i find fog light on/off switchs?
bceolla
I'm about to buy a Defiant 03-09 4 RUNNER - SHORT TUBE light bar with 4 lights, but i need a light switch button. The type of button that is used for the DAC. I can't seem to find anything about it. Please let me know if you know where to look.
You can get the OEM switches from a dealer. A search on the forum might turn up the part number for the switch you want. I think you have to be careful about the amount of current you put through the switch, as the OEM switch is probably designed to turn a relay on and off. I don't know if you can put an OEM switch between the battery and the lights. I'm sure someone who has done this will have more insight.
something like this?
FJ Cruiser Aux Light Switch
part no: PT297-35070-AS
$43 at trdsparks.com
The photo above shows the FJ Cruiser Auxiliary Light switch and here are the Toyota Part Numbers.
Switch: PT297-35070-AS
Wiring Harness: PT297-35070-SH
Pinouts:
Pin 1 (Red w/ Blue) : Illumination Power for "Lights On" indicator light
Pin 2 (Black): Ground for Illumination circuit
Pin 3 (Green w/ purple): Switch Power (12V Supply)
Pin 4 (Red w/ green): Line Out to Relay
Pin 5 (Grey): Ground for Backlit Illumination Circuit
Pin 6 (Purple): Illumination Power for Backlight
A link to an auction that is not mine that has both the harness and switch: FJ CRUISER FOG LIGHT AUXILIARY DRIVING LIGHT SWITCH: eBay Motors (item 320527738716 end time Jun-04-10 15:48:25 PDT)
Yeah I just looked there and they don't sell them anymore. Where could i find them now? And how many would i need for 4 KC lights (2 pair).
You have to search under FJ Cruiser, they're not listed for the 4runner
TRD Sparks FJ Switch
Wiring Harness
TRD Sparks FJ Roof Switch
I have one for each pair of my front lights and one for my reverse, but I recently changed it to one switch for both fronts and I will use the other switch for some roof lighting. You can use 1 switch or 4 depending on how many lights you want to come on with each switch. I found that I never turned on just one set of lights so I just wired all four front lights to 1 switch.
Is it easier to put the switches next to the steering wheel, or by the arm rest?
It's about the same either way really, just a couple of extra feet of wire and different interior panels removed. Both locations have a place to tap into the illumination. I think it's easier to use the buttons on the console because I usually keep my right arm on the arm rest. I also didn't have enough spaces on the dash for 3 switches.
alright. And do the interior panels just snap off or something?
Yeah, just push them out from the back. there is a little claw on the top and bottom that you can squeeze to make it a little easier. When you get the FJ switch, you will see how it works. You can see the tabs in this picture. Both switches have tabs at the top and bottom that hold it in & the blank panel is the same way.
New Guy
Hey Guys, I'm new to the site and already need some help. I have a 05 runner and i bought a fog light switch however i'm looking for the plug with the 4 wires that plugs into the back of the switch. Anyone please........... do you know where i can find this?
if you have a 4-pin fog light switch then it's probably a tacoma switch. if so, they you'll need the following:
(1) Connector Housing - #90980-11090
(4) Wires for Connector - #82998-12340
You can find the parts here: Partznet
Contact the dealer or search form net. There are lots of sites who sale the new and used parts. You can find this switch from Ebay also. This is also a one of the good place for buying auto parts.
Im bringing this back alive. I have the issue of all these light and I need switches that look OEM. Thanks darkie3495, and gaterose for your input
Pinouts:
Well I ordered all this and found that the green indicator stays on regardless of switch position. Could it be a bad part or am I missing something?
That doesn't sound right. Is pin #1 connected to the same line as pin #3? Pin #1 and pin #4 can be connected together to send the 12V signal to the indicator light.
Yup, I went through all of this. I figure the switch is faulty. It is going back today for a replacement.
stumbled onto this...
Bookmarking: I'll be looking for one of these switches soon as well...
Try Partznet.com:
Type in these part numbers:
1-switch 84160-04010
1-connector 90980-11090
4-pigtails 82998-12340
Partznet has all three parts for $53 (pick up only, shipping extra)
