Who is interested in a "behind the grill" light mount bracket?
[MENTION=98089]c2one[/MENTION] AWESOME. Very nice clean install!!! Thanks for posting pics!
Still 2 brackets available guys! PM me if you want one.
Better view of bracket.
And quick wire just to make sure lights work.
What type of led bar is this and how long is it. Looks like a 20". Any pics with the grill back on?
I have a 30" bar on backorder right now. I purchased SoCalTrail's blemished light mount bracket. I plan to use a Rigid cradle mount for the led bar behind the stock grill. Pics to follow when everything comes in.
PM sent. Anyone on here that might know where to find a pic with an LED light bar mounted to one of these behind the stock grill?
The light bar is Hanma. The bulb housing area is 20 inches wide. Total width including side mounting brackets is about 23 inches.
I'll take some pics with grill back on, haven't done it yet. But I will say that stock grill does block a lot of the light bar, probably around 35-40%. I was planning on doing a Satoshi grill before I did the light bar but as [MENTION=75328]DannyLlama[/MENTION] said..."Get'em before they are gone"... I didn't want to miss out on one of these brackets. And because I already had everything (light bar, mounting plate, and OTRATTW switch) I decided to go ahead and get this all set up. Now I have to make a decision on a new grill soon.
I was wondering about that... good to know.
What about losing the emblem and keeping the stock grill?
If you pop out the Toyota emblem there is a matching outline of the emblem behind it. So there wouldnt be much of a difference.... unless you wanted to cut that part out. But even if you did that only the 2 middle LED bulbs would shine through unblocked. The 'wings' that are on both sides block a good part of the light (less than half of the top part).
I kind of knew this was going to be the case going in and was trying to find a way to mount them lower (that's why I went with a Single Row LED Bar). But I'm no engineer nor do I have the tools to be able to create something on my own.
So using [MENTION=74569]SOcalTRAIL[/MENTION]'s bracket was the best solution for me ... after reading how burly it was and was, for me, the most secure way to mount lights I decided to change my grill instead of keeping the stock grill (even though keeping the stock look was my first choice).
I will take some day and night pics today.
Make life easy on yourself and get this
Don't worry the Grill Craft emblems pop off...
Then you just add whatever Toyota emblem you want (or not).
Thanks for the link..
Does anyone know where to get custom emblem's done?
[MENTION=74569]SOcalTRAIL[/MENTION] Sorry for the going off topic.
:llama:
Here's the front of what the grill craft setup looks like (ignore the two guys working underneath :rolleyes: ) This also gives you a good idea on the mounting of four visionx cannons behind the grill and two PIAA 510 ion yellow fogs in the lower grill... might be time for some LED cubes down there
That is Awesome [MENTION=50210]KVA[/MENTION]
Too much getting blocked...totally get the grill or make your own...it will make a HUGE difference with that light, wiring, and bracket investment. Not to mention it will make SOcalTRAIL proud.
brendaglores
