Will these wheels fit my 2013 LTD?
Neauxla
Katana Wheels Kr10 Gunmetal Rim By Katana Wheels - Starting from $107.00 with 5 SPOKE, Free Shipping and Free Warranty - Buy Wheels and Rims Online from Performance Plus Wheel and Tire
Looking at the 18x7.5s
NO will not fit, +45mm is too much backspace, you want something -12mm to 12mm. Plus the bolt pattern is not right either.
Thanks. Trying to find some 18"s b/c I don't want these rubber bands on my 20"s and I don't want to lift my LTD. Want biggest tires that will fit w/o rubbing and would like to go bigger than 17"s.
the problem is most 18" wheels if not all of them that will fit the 4runner are 18x9" and a stock tire size of 265 wide will not fit, the rim is too wide. I think you need at least a 275 wide tire, a 275/65/18 would only be .4 inches taller, you could run that without any lift with a 0mm offset wheel.
So 18" wheels are going to be too wide for tires that will increase my height w/o rubbing is what you're saying? Forgive my ignorance.
No - what roktoy said is that MOST, not ALL 18".
Go to this link and play around with the sizes.
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
It even tells you how much of a difference in your speedometer it will make.
Also use this chart to get the back spacing correct:
the 20" stock wheel 7" wide with 4.5 backspacing and offset of +12.
So you want to be close to those numbers. Your search wont be easy unless you go with a wheel that someone else already has on this forum.
For Example:
Mine are 18x8 with 35MM off set, so that leaves me at close to 5 backspacing, which is .5 difference from stock. Basically, they fit.
That really should give you all the ammo you need to find the right wheel.
Good luck
For Example:
Not gonna lie - that sounds pretty crazy to me that your wheels even fit with those specs without rubbing (I'm assuming you don't rub). 8" width and 35mm offset comes to BS of 5.88". Most of the talk I have seen on here is that you should try to stick to around 4.5" BS (as you even mentioned yourself).
Are you running wheel spacers with those?
Those wheels might fit, but with a 20mm offset, it will bring the wheels closer to your suspension by about .3" and if you go with a 265 tire, that brings it .7" closer. with a 275 tire, that's almost 1" inwards. Most of us try to go with a wider stance, because the tire being tucked inwards in the fender doesn't look as good. I would really try to find a wheel with 0mm.
If you really want a 8" wide wheel, there are many more choices in a 17" rim.
Remember if you are getting a bigger wider tire than the limited wheels/tires, you need to bring the wheel offset further out to clear the suspension. -12mm is further out, the more positive offset is closer in (+12mm)
Use this online calculator, it will help you to decide. You don't really want to get closer to the suspension, keep it about the same or further out.
I also suggest going to tirerack.com
http://www.tirerack.com/wheels/resu...lse&filterNew=All&filterWeight=All&sort=Brand
or discounttire.com and plug in your 4runner, it will suggest wheels that fit the 4runner.
Sorry, I meant 15mm.. These wheels actually come in 15 or 35, I mean to put 15 in my post. Comes in just under 5.25. Good eye
