Window Weatherstripping Replacement
It is unlikely you will need to replace the rear hatch window seal/weatherstripping. The weather stripping breaks in the thin, flexible spot. On the rear hatch weatherstripping this is protected from sun by hard plastic.
This part was only $20 at Camelback, but I suggest you check yours before purchasing this part.
Yes, avoid the rear hatch weatherstipping! It has a much more positive lock on the door panel and therefore is much more difficult to remove and much more risky than the other weatherstripping (you may damage the hatch body panel), and there should be no need to replace it!
I had already mangled the old weatherstripping a bit and was struggling with the decision to continue. I did get it off and it came off cleanly, but it takes force and commitment and it was scary. I started in the middle (both ends insert into the vertical side molding) and I applied a lot of force with my screwdriver inserted deep into the part.
AGAIN: I DOUBT THE REAR HATCH WEATHERSTRIPPING WILL FAIL BECAUSE THE WEAK, THIN PORTION OF THE RUBBER IS PROTECTED FROM SUN. AND IT IS MORE DIFFICULT AND RISKY TO REPLACE THIS PART.
First of all, thanks to all who contributed to this helpful post.
Just ordered all four belt moldings from toyotapartsestore.com. Price for all four was a little over $200. Just shipped yesterday so will put them on as soon as they come in.
As for the rubber on the liftgate release switch turning to mush, mine is actually dripping. I found just the replacement rubber (instead of replacing the entire switch) on amazon for $13.95. It's on order and should be in soon.
https://www.amazon.com/gp/product/B...beb-4819111bef9a&pf_rd_r=F7P803K8DDRQYKSTENMS
Just a word of caution.....A few days after I ordered the belt moldings from toyotapartsestore.com, I had some fraudulent charges on my debit card. Not accusing the website directly for the fraud, but there's a good chance they may have been hacked and customer info was stolen. Had to shut down my card and order a new one.
Thanks for posting this. It was a great help. I didn't need a screwdriver, just used my hands. Whole job done in less than 15 minutes. I did the work in the morning so I will hold off on the adult beverage.
Thanks chitown616 for the photos and description, just replaced my driver side and doing the rest soon. Got it done quickly. I already had a set of plastic pry tools for working on interior and also applied masking tape on paint for a precaution. When I installed new part I applied some silicone spray to ease installation but it went in so easy I'm not sure that was necessary.
Thanks again.
2010 Trail.
For those looking to replace melted switch cover in rear hatch there is a page already in Forum: Help: Hatch Handle Melted
A YouTube video link is : YouTube
This can easily be done from outside.
A couple of updated tips...
1. Restating the above. - on side doors position your new tabs over the slots they need to fit into before you start pressing down to seat the entire belt molding. It presses on very easily so just get it aligned well right to left first.
2. A felt edge squeegee tool is ideal for this and including the rear hatch belt molding. Th e non-felt edge is soft and tapered. Once it is pushed up it will actually snap the side door belt moldings loose.
It will also pop the clip on the end of the strip right up. No issues at all. Just insert and push. You will hear the little snap sounds as you go. Then just slide it down the line. Then with both hands just pull up and roll forward on the entire strip.
3. Rear Cargo Door. Same felt squeegee but this time push it as far up as possible. You may hear a "snap". At that point the trim is still not loose bu the squeegee make a big space. Now with a wide pry tool wrapped in a rag push it up towards the roof and pry it a bit. You will hear a "crack" sound. Louder than the "snap". Do that the entire length.
Do not start in the middle. Start between the middle and either end. Do those areas. Then work towards the middle from both sides. The middle seems tighter for some reason.
My piece came off intact and could be reinstalled if need be.
On the front door pieces if you are saving them for emergency fix if they are not already torn up.... the point where strip joins the section with the rubber wiper will crack if you pry/bend it up very much at all.
So overall if you want to save these things or if happen to be doing junk yard pulls. You don't need to deform them much to get them off and the little 4" section with the clip will break where it joins the larger section with wiper so don't bend that area if you help it.
Possibly the easiest fix you could ever do. Here is the tool that seems designed for the job.
ebay link may expire. Just search plastic felt edge squeegee about $3 - $5. I suppose the plastics could vary. Mine was white and stiff but soft pliable tapered and rounded plastic front edge..... unlike the hard plastic auto pry tools.
On the rear hatch my big pry bar was actually a 18" metal one. But you don't really pry with it. You just want something wide with a somewhat dull edge ( wrapped in cloth ) and long enough to push upward in the gap the squeegee makes. It just pops those catches the last little bit.
https://tinyurl.com/yd5yagom
Damn this site is good! Literally just had this tear off when rolling up my window this morning and was going to ck here for solutions, then bam! It's a top thread on the first page. Freaking reading my mind! Love it.
Double check your parts numbers before ordering...
The rear window numbers above are reversed; 757 21 35011 is the right rear not the left rear......
Thanks for this!
I joined up here today because this post was excellent and I used it to order weather strips for my 4runner.
I appreciate all the effort you made on this, just outstanding!
Thanks again!
David in OK
I have purchased the front strips previously, but just ordered the belts for the second row and the rear hatch. They have needed to be replaced for some time. OEM Part Source seems to have the best deal right now. No free shipping, but after using the code 10OFF, shipping was only like $10.
Part Number Price
75721-35011 $39.16
75722-35011 $39.16
68292-35041 $25.62
Subtotal: $103.94
Estimated Standard Shipping: $11.09
Discount: -$1.11
Total: $113.92
Easy-Peasy...
Thanks all! Antman I think that is the process for the inner window weatherstripping! Which will probably be next on the list. Deep.. you are correct.
After an adult beverage and looking at the new pieces I gave it a shot, figuring there was only 1 clip that was actually holding in. 30 min later all 5 outer weatherstripping pieces were done. $600 my as* Findlay Toyota Flagstaff. This really could not be any easier. You just have to be careful when removing not to scratch the paint on your door.
Here is the process......In order of photos.....
1)Buy parts...
Front Drivers- 75712-35011
Front Passen- 75711-35011
Rear Drivers- 75721-35011
Rear Passen - 75722-35011
Rear Hatch- 68292-35041
2)Locate the clip on the specific part you are replacing and locate it on the one thats on the truck.
3)PRY UP CAREFULLY. I used a standard screwdriver wrapped in duct tape. Deep a plastic putty knife is a good idea. THIS IS THE PART TO BE CAREFUL WITH. You can scratch your paint pretty easily if you are not careful. Use your fingernail to get the weatherstrip piece up, then use your tool to go under it and keep going up. You will probably break the plastic clip off, but you thats okay. Just use pressure and get it up and off.
4)Grab the now loose piece, and start working it out of the channel it is in by the mirror, once that is done you can pull it straight up and back.
5)Throw the broken piece at your neighbor.
6)Clean off any left over plastic crap.
7)Start installing the new piece with the end in the mirror channel first. Then working it down until the clip os in its home. Press down firmly over the entire length to ensure a tight fit.
8) REPEAT!! The rear doors have 2 clips and the hatch window has none. The hatch you will end up mutilating, but thats okay. It installs as easy as the others.
9) Enjoy adult beverage and your work!!!
Had it in my mind that I was going to have to pull door panels to install the new moldings. Part numbers are correct, procedure is correct, everything posted above was very, very helpful. Thank you!!
Its been some time since I've been active on this forum and much like this forum, my 4Runner has been neglected over the past few years.
I am getting ready to sell it and noticed the passenger side weather stripping is failing and I'll have it replaced prior to selling. I love how easy it was to find this thread / process / info.
Too easy! Thanks all!
My front passenger side just went. Thanks for this write-up.
Parts ordered from Roseville Toyota.
$177 shipped for the 4 doors. Prices have gone up since 2015.
Other places had them a bit cheaper but shipping was higher.
Appreciate the write-ups, but to the original poster's comment (from way back when), has anyone had any luck getting these replaced under warranty?
I took ownership of a new 2019 earlier this year. If it's rained, the window is dry, I put it down, and then bring it back up and it's wet. Now that it's gotten cold here after a rain, the window is frozen shut and I hear ice in the door when I close it.
Understandable for something that's been sitting in the elements a few years, but not a brand new vehicle.
My weather stripping was either installed wrong or was garbage to begin with. And it's all 4 doors, too. I'm not big shelling out the amount required for the parts here...which sounds like it's over $100, for something so new.
Looking to hear any stories...
I just noticed my rear hatch trim fall apart in this southwest florida sun. Bought the part off amazon, had to pry the old one off with a padded putty knife, then used plyers to grab the top of the trim and pull. No issues, no damage to the body. Cleaned the metal on the body with an old shirt and water, then snapped the new one on..in 5 mins. Thanks again.
I love it when a 6 year old thread saves the day! Got the part # and saw the note about a TR4 discount at Camelback.
