Windows control help!
DannyLlama
Elite Member
Swapped out OEm battery today with group 31 Northstar and a Bussman fuse box. After turning car on, everything wokrs with the exception of the driver side window controls for the passenger window.
The driver control pannel works for driver side window but not for auto up and works fine for the rear windows. Though not the passenger window. However the passengerside control works fine.
Any suggestions?!
Check the manual, but I think if you lower the passenger side a bit with the passenger side switch, then raise it back up and hold for like 10 seconds, it resets. Some kind of anti theft safety thing that they put in. See if that works.
Any suggestions?!
Soooo.....try this.
Crookedcat
