Windshield Sprayer not Working
kschwed
2014 SR5 Premium.
Went to use the sprayer this morning and nothing happened. I've never used it before. I can take it back to have the dealer look at it, but if it's something I can fix easily, I'd rather just do it myself.
I checked the fluid and it's full.
Any ideas?
Thanks.
2014 SR5 Premium.
Any ideas?
Thanks.
Check the fuse first. See if it's something there. Does your rear one work?
It hasn't been consistently below freezing where you are has it? My washer fluid froze last month when we got cold snap here in VA Beach. Apparently the Dealerships here are using diluted washer fluid not de-icer.
EDIT: Didnt see your location until after the post - I am assuming temp is not a issue :)
Yeah, it's never been below freezing here in my life. hah.
I'll check if my rear works. Is the fuse for the front and rear the same?
Check fuses since the fluid level is good.
Has is had any kind of body repairs, paint work or any other reason for the hood or washer fluid lines to have been disconnected since the last time you used it? I've seen it a few times that the one-way anti siphon valve get reinstalled backwards.
Did you use tap water to fill it up, sometimes the shitty water clogs up the little nozzles.........?
Can you still hear the washer motor running when you try to wash the windshield? If you can hear it running it's probably a blockage, if you don't hear it it may be a fuse.
what are your night time temps like? mine froze the other day went to use them and the liquid was frozen and they didn't work until I got back into warmer climate, I was in lake tahoe at the time about 20 degrees
increasedc
