You've been recalled (Gas pedal modification by the dealer)
The keywords in the recall that stick out to me are:
"Toyota has determined that this defect does not exist in vehicles in which the driver side floor mat is compatible with the vehicle and properly secured."
I don't think I have anything to recall. And I'm using the nice 4Runner All Weather mats which are properly secured and do not interfer with the pedal. (Toyota can have my all weather mats when they can pry them from my dead, cold hands! :D )
The excitement concerning the recall for the 4th gen 4runner is nothing more than FUD.
Mine had the mats removed by the dealer when I bought it in 3/10. You could not get them from any dealer then either (I asked a few). I went with the weathertech, but wondered why there was not a recall when they could not get them then.
In case you haven't noticed, you can register at the official owner's site with VIN#. I registered 2+ years ago but hardly returned. Just found out the site actually have all my oil change etc service history done at Toyota dealerships. Don't think they had this info back then when I first registered. Could be helpful.
Toyota Owners - Official Toyota Owners Website
What theyll do when you bring it in is to inspect the floormat to see if its attached to the clips properly. There are three options based on the inspection:
1) Carpet mats installed correctly. Inspection complete.
2) All weather mats installed. Replace with updated thin mats.
3) Aftermarket mats installed. Remove and place in trunk/cargo area.
When the toyota allweather mats are removed they get cut in half and sent back to toyota. Period.
Btw, this isnt a recall based on any real danger. The gov't cut a deal with toyota. If they recall the rest of these vehicles the gov't will close the investigation. Toyota took the deal. Its cheaper than more bad press dragging this out longer.
Seems like it is more than that. The local newz tonight showed they were dealing with the plastic molding that is over the center console beside the gas pedal - Not just the mats. They showed that it can come loose and catch the pedal.
I'm thinking another part of the recall will also involve an ECU reflash to include the electronic brake over-ride fix that went with the other pedal and mat recalls.
No - that would actual be beneficial. They can keep their hands off my Toyota all weather mats unless they plan on giving me my money back for them.
i called in to register mine and must have told the asian-american lady my VIN 12 times, to which she responded "such a vehicle does not exist!" i really wanted to be mad, but was laughing too hard!
I've seen where lots of people stack the all weather mats on top of the carpet mat. In that condition, you can pretty quickly eat up the clearance. This is a case of Toyota being overly cautious and trying to cover any situation where someone can improperly use the mats and slam their vehicle into something reopening the can of worms.
I don't know how they will prevent people from hitting the wrong pedal, though.:ybrick:
From what I've read, the dealer will ensure both the floor retention are functional and installed properly and replace the carpet/rubber driver side mat with one with a larger cut-out under the gas pedal.
On the other Toyota models that had the "floor mat" recall last year, they cut off about 1" (give or take) from the bottom of the gas pedal. The gas pedal assembly is actually pretty simple - it's a box mounted to the firewall with an arm sticking out of it. The arm is a single, solid piece of plastic that also includes the flat part where you put your foot. Toyota made metal templates specific to each model that the tech uses to mark where to cut, and then they just cut the plastic along the line. A little sanding to clean up the rough edges and they're done. I have seen it done, and it's not as bad as it sounds because it's plastic and it cuts pretty easily. If customers are unhappy with the cut job *after* it has been done, they can complain to the service manager and request that a new pedal could be ordered through Toyota. Toyota will replace the whole thing at no cost to the customer, but only if the cut job came out bad.
On select models getting this done, they also flashed the engine ECU with a new program that includes a brake override system. The override will cut engine power when the brake is applied under certain circumstances. This set of conditions must exist:
1. The throttle is more than 1/3 open (usually because the gas pedal is depressed)
2. The vehicle is moving more than 5 MPH.
3. The brake is then applied firmly while 1 and 2 are both true.
If the override kicks in, it is released when the brake pedal is released.
If you press the brake pedal first and then apply gas (trying to start uphill, for example), the override does nothing. The override also doesn't function in 4LO on 4x4 models.
Finally, the dealer is supposed to inspect the vehicle and remove any floor mats that are not properly secured, or floor mats on top of other floor mats. Toyota has only replaced their OEM all-weather floor mats with a different design as part of the recall; the carpet floor mats are not changed.
Once the recall solution has been announced, keep the recall in mind if you ever have to go to a dealer and don't want the work done. A lot of dealers just do recall work automatically while they have a car because it's usually easy and it's work that's paid for by Toyota instead of the customer. In other words, it's revenue for the dealer. You'd have to tell them in advance that you don't want the recall work done.
All they did on some cars was cut down the front of the gas pedal. Depends on if you have the Denso gas pedal or not. That's right, only the Japanese pedal was ok, the ones they used in American-made cars was the one having electrical issues. I'm not doing the recall. I'm not afraid of it catching the mat.
This is exactly what they did to my Tacoma. I had it at the dealership because the differential was grinding and they told me that my truck was part of the recall. They cut a piece off the gas pedal and called it good. I had aftermarket mats, but I didn't want the outstanding recall on my truck if I sold it in the future.
On the Toyota Canada site, the recall is up as well (16,000 doesn't seem like many for all those years - maybe just selected ones?):
As Toyota USA is amending their floor mat campaigns, Toyota Canada is also amending its safety improvement and safety recall campaigns that were initiated in the fall of 2009 to address the potential risk of an unsecured or incompatible floor mat interfering with the accelerator pedal. The models added to the safety improvement campaign include:
* 16,000 2003 through 2009 4Runner; and
* 99,300 2006 through 2010 RAV4
Not surprised the 4Runner has now been included in the recalls.
I bought the Toyota all weather mats in 2006 and laid them on top of the carpeted ones, so they were not secured.
On a number of occassions I have been caught out and had to panic break and slam it into neutral. Would have been wreck on a few of those occassions if I didnt have quick reflexes.
That was all my doing and my car doesnt need any fixes... I did try an replace the fronts a couple of months back, because my heels have worn through around the accelarator, and was told they no longer stock any all weather mats for it...
Still want weathertechs, just cant part with $270 for a set of rubber mats.
Okay not to get everyone excited but I was at my dealership today to see if the TRD intake was available for my 2010 Trail and I noticed a ridiculous amount of weather tech mats not the digital ones but the regular rubber ones so I asked whats will all the mats? He said they are for the recall so it looks like they are replacing the Toyota mats with weather techs at least here in my town not sure about everybody else just throwing this out there for you guys
Well now I'm interested, considering one of mine is torn up anyway, will have to see what my dealer has..
I stopped by the parts counter for something else a did notice a HUGE stack of WeatherTech mats .... guess I'll wait on buying a set until I see whats going on ...
