06-09 LED headlight bulbs. MUST TRY list
I have been complaining about the stock output for years now. Just ordered some for highs, lows, and fogs. Free same day through Amazon so they should be here this afternoon. Someone can confirm with me in case I need to edit the order, but lows are H11, highs are 9005 and fogs are 9006, right?
I have them in high beams as well. See my pics earlier i the thread.
Oops... I did not post pics
Mine came in the other day, easy plug and play in about 5 minutes. I did connect one the wrong way on the plug and it did not fire, reversed it and worked started right up. I dont have any experience with LED's or HID's, but these seem to be a big improvement over the stock H11 bulbs. It should really help on those rainy Pacific NW nights where it is hard to see the lanes.
The only thing I dont like about these so far is that they do emit a slight buzzing sound that I can hear in the car with the engine idling.
Before
After
Anyone run these in high beams or fogs?
Glad you like them. The fans make a whirring noise... They are located at the back of the bulbs to cool them down.
I have the Auxbeam LED high beams and fogs. They are ridiculously bright.
These give so much light that I wont need to use my fogs all the time like before, so I think I will start off with brights.
That’s frustrating. Have you considered going back to OEM housings? I’m keeping mine just in case. If these fail, popping the OEM open, rattle can matte black.
I will take these $29.99 bulbs over full retrofit 1k headlights any day! Lol
Hmm... You know you can adjust both vertical and horizontal adjustments right?
my problem was the lens was off to one side in the headlight
Same model, right? Did you get the CANBUS conversion kit from Auxbeam as well?
https://www.amazon.com/Auxbeam-Conversion-Wiring-Harness-Adapter/dp/B01N2OI1KN/ref=sr_1_fkmrnull_9?keywords=Auxbeam+9005%2F9006+LED+Conversion+Kit+Error&qid=1551766508&s=gateway&sr=8-9-fkmrnull
Nope. I have other LED’s for my DRL/Turn signals that come preloaded with resistors. No error codes for me.
What LEDs did you use for the DRL/turn signals? I really wanted to use LEDs there but after reading many articles about the hyper flash issues, and having most disable the DRL function to solve it, I concluded it was more trouble than it was worth, especially since I really like the DRL function on the ‘06 style lights. The main reason I want LEDs is because the bulbs eventually lose the deep amber color, probably due to the heat from running all the time. They go from a nice deep amber to a pale yellow after about 6 months in my experience.
I have zero issues with my DRL and turn signal LED’s. The DRL function works flawlessly. No hyperflash with turn signals as these have built in resistors. The Amber is deep as well. Very happy with the following.
Front DRL/ Turn signal bulbs:
VehiCode Super Bright 4800 Lumens 21W 3156 (3156A/3056/3456/P27W) LED Light Bulb (Amber/Yellow) Built-in Resistor No Hyper Flashing CanBus Error Free Replacement for Turn Signal Light (2 Pack) https://www.amazon.com/dp/B07FK9TRZK/ref=cm_sw_r_cp_api_i_o5NFCb9FHPEPE
Rear turn signal LED bulbs:
iJDMTOY (2) No Hyper Flash 24W High Power Amber 7440 W21W T20 LED Replacement Bulbs For Car Front or Rear Turn Signal Lights (No Load Resistor Required) https://www.amazon.com/dp/B074RLJMWQ/ref=cm_sw_r_cp_api_i_J8NFCbH213DGC
A few pictures: The cutoff seems the same as the original. They really light up the road without being intrusive to oncoming traffic. I like the way road signs pick up the LED lighting. You can see far down the road off to the left the green sign is lit up. My stock headlights did not do this from what I remember.
for the price I may have to give this a go. Just ordered 06+ headlights. Eventually I may still do a hid retrofit so that way I can get dual high beam setups for backroads.
Thank you for posting this! I know many people like myself are on the fence and this just made it a much easier choice.
Pics look good. Impressive right? Night and day difference. I aimed mine a bit lower, (so the beam sits below the average compact car’s rear view mirror at 25 feet), so I don’t light up road signs a mile out and piss people off. My fog lights however... those definitely light up the road signs for me and I only use them when absolutely necessary. With the way these headlights light up the immediate area directly in front of the vehicle I don’t think my fog lights are even necessary to be honest.
erinobr2000
