2 many broke runners build
With the help of my son rylan and buddy Eric got the truck moved to the other side of the shop.
Started removing the body lift. Custom made from previous owner
Here's the before
And the after
We also removed the engine mount lift
Got some of the frame cleaned up a bit more. Those ifs brackets suck to remove. Left big holes in the motor mount area.
A piece of 3/16 plate fills it nicely
Welds to the frame were great. Ones on top to the bracket sucked
Other side finished up nicely
Mocked my steering box up again. Flexed it to make sure spring don't hit anything.
Drilled holes for the box. Going to plate frame next time and bolt the box up.
Got the holes drilled for the frame tubes. 3/4 drill bit with big drill will twist out of your hands quick.
Had to trim the front edge and bottom of the plate from TG.
Tacked the tubes in place. Then welded the plates to the frame.
Meanwhile my buddy eric cut the front crossmember out for a receiver hitch.
Finished up gearbox install.
Also plated front crossmember with 1/8 inch steel.
also ordered stuff for hydro assist:zoom:
Thanks for sharing the box mounting pics. Looks like I will be trimming my TG mount too :(. I'm mounting mine in the same spot on my '87
Got the front x member plate welded today.
Also cut the tunnel out some
And started on my homemade x crossmember
Will go up a bit higher just need to clearance the sheet metal a bit more.
Well I got the transfer case crossmember about done.
Got it mocked up first, not going full flat belly this time.
Next plated the frame for the mounts.
Made some mounts out of a piece of channel cut in half.
Than tacked it all in place
Than welded the plate back together
Still need to grind it down and add to the front for a crawl box mount.
Painted the axle and got the knuckles freshened up and axles and diff installed.
Also installed for last time I hope.
Got the frame mounts welded up
Also added some gussets
Thanks Hyde. Got some stuff done yesterday had to cut the day little short to do a side job.
Here's a couple of the t case mount.
Cut the tunnel out little more
Cleaned up some frame rust for more plates
Plasma out some plate 11gauge I think
All to mount a new horse collar crossmember to
After a lot of trimming at funny angles in the band saw.
I got the pieces for the new horse collar crossmember tacked in place
Than measured the the center piece and welded it together and to the plates. It's not perfect but it warped a bit while welding out of the truck.
Been busy havent updated this in while so to catch up
I tried to shorten my rear driveshaft with some sch 40.
turned out very out of round
so i bought a new peice of pipe turned out to be sch 80 not 40
Cut the spare tire crossmember out for placement of the gas tank
welded my old 2x3 box tube bumper on the back of the frame rails
cut a small hole for the gas tank to peek through
Plasma made quick work of this hole
ALso trimmed these down for my taco rotor swap
made some brackets for the gas tank to mount to
gas tank is secure
just need to hook it all back up build a box for it to isolate it from passenger compartment.
Well found out the hard way that my taco calipers don't it allied bead locks.
They grey color is were I still need to grind the caliper
got the wheels on finally
Made a neat air filter adapter for the maf
not shown in pics i built a mount to hold the thing up very heavy
Also worked alot on the brake lines fuel lines and extending the fuel pump wiring.
got all the fluid topped off and backed her out finally
I didnt get to far off the road but she will flex a ton more.
Ambrose67
