octanejunkie
Elite Member
I have a stereo, so all I need is the adapter and dash kit [emoji57] thanks [emoji106]The adapter was ~$6, the dash kit was $20, the stereo was an open box from Frys for $25.
Sent from my Nexus 5X using Tapatalk
I just ordered both parts off Amazon for under $15I edited my post after looking at everything again.
Just get the Metra 88-00-8000 kit, because all you need is the cubby.
And Scosche TA021 adapter, or whatever adapter is about $6 and has these plugs:
https://www.amazon.com/Scosche-Harness-1987-Up-Speaker-Connector/dp/B00009UHKW
I ordered a harnessIt's a lot simpler if you just go buy a harness from somewhere. Best Buy, any audio place...possibly even Wal-Mart. Then you just have to tie it straight to the radio harness and not have to worry about digging into your trucks wiring. They're fairly cheap.![]()
Got my Metra "pocket" 88-00-8000 and Scosche harness TA02B from Amazon last night and gonna wire up my replacement radio tonight
Will doGreat, let us know if that cubby is the same one that was included with my Raptor kit.
If so, we'll have a definitive list of parts needed.
The Scosche harness on the other hand, not so much. My radio has a 15-pin connector that integrates with the factory amp. I intend to keep the amp.
The Scosche harness is a 2-piece set that won't mate up to the 15-pin plug in the car.
Exactly what he said. Connecting your new head unit to the factory amp is probably going to cause some issues. I don't know the exact specs of wattage from the factory deck going into the factory amp but I bet the aftermarket deck is way off.
But hey if it sounds terrible just use it until you can't stand it anymore then buy the Alpine Universal Power Pack and some decent (not overkill) speakers.
From the looks of your pics, the Metra pocket I got off Amazon is smaller, shallower and has less volume (due to thick plastic walls) than the one in your pics.Great, let us know if that cubby is the same one that was included with my Raptor kit.
If you're installing an aftermarket deck, odds are you wont need that stock amp. Unless you bought a deck without internal amplification. If you pull out the amp, you'll find that your existing wiring harness should work with the harnesses that plug into the amp.
It's already done, just installed it.Yep, that.
Any aftermarket stereo should have it's own amp.
Rip out the factory amp, use the $6 TA02B harness.
Why a 150 buck power pack and not an amp? You can score a 4 channel amp with 125 RMS per channel for under 60 bucks. Sure it's a little harder to wire but for the money it would be the way to go IMO.
Question regarding BAT power to the new stereo - where to source?
Now I need to get the antenna to go up
This is just my personal opinion but I simply don't believe you can buy a quality new retail 4 channel amp with 125 W RMS power channel for $60 US.
The Alpine Power Pack has a great reputation which is why I recommend it. And at 4x45W RMS it packs more than enough punch at very good quality for a consumer amp.
I have an Alpine amp powering my Kappas at 75x4 RMS and it has always impressed me.
Simply put in terms of clean power and sound quality a Watt on one amp is not the same as an Watt on a different amp.
