bluecollarjock
Yep, using the dealer for simple maintenance is always a dicey proposition. I took mine in for the free 10K service, and asked them to change the oil only, not rotate the tires. I walk out on the drive, and sure enough the tires had been rotated.
On the tire wear note, mine are cupping quite a bit(both sides) on the inside of the tire. Tires have been rotated every 5K. I am now at 15K, and they will probably need to be replaced in 5K or so. I drive like an a**hole though, so that might have something to do with it.
A buddy of mine has a Pro, and his tires were worn enough on the insides that he just replaced them at 20-25K. He had an alignment done at the same time, so it will be interesting to see how this set of tires wear.
That is disheartening to hear, two different people probably replacing tires at 25k. Mild ATs on a stock SUV you'd hope would do 40k without skipping a beat. I think I easily got 70k miles out of my stock tires on the last brand new SUV. I was not off roading though, just highway miles, snow, dirt roads worse they saw.
