4th and 5th gen springs interchangeable?
jeangtd
Hi,
do you guys know if the rear springs on the 4th gen are interchangeable with the 5th gen? i need springs that can handle extra load for a lot of accesories and luggage but dont want any lift and i think ome895e would do the trick but they are for the 4th gen, i want to fit rear 2.0 or 2.5 icons.
thanks a lot
Hi,
thanks a lot
Yep , 895E's will fit and and as Falls said give 1 1/2" lift and are reported to have a pretty firm ride.
Another option for you since you said you didn't want a lift is to airbag it.
Here's the airbag's....Toyota 4Runner Air Bag Helper Spring Kit 2003-2011 - "Air Lift 1000" Suspension by Air Lift
And here's the thread with discussions about them..... http://www.toyota-4runner.org/5th-gen-t4rs/62499-airlift-1000-install.html
when i load up the truck, i lose about an inch of ride height, and i feel its unsafe on bumpy highway roads like we have here ( i am in Bogota, Colombia) its so heavy and roads are so bad i bottom out the suspension from time to time. having this in mind, what would you think the truck will hanlde like with the ome895e?
i think you have the right idea getting some heavy duty shocks to go along with the firmer springs. the stock shocks, IMO, aren't going to be able to damp enough.
new2yodarun4her
