Just wondering if Kdss is so necessary for off road articulation, why is it not offered on the Pro?
I think it's a cost thing - or at least it was originally and it's carried through without it. TRD Pro parts used to be sold at the parts counter. Then they made a trim that included them called the TRD Pro where they were installed at the port. I'm not sure if it's still the case that the suspension and bumper overlay is installed at the port or if they've moved that to a factory installation.
My guess is that KDSS makes the swap of the suspension at the port a lot harder and it cause more issues with KDSS lean when they changed the front ride height. It was too much extra effort to re-level it, or the re-leveling didn't work. That's one potential reason to drop KDSS.
The other is that the heavy sway bars are a lot harsher in the mid-speed ranges. Between 10 and about 25mph, KDSS is pretty harsh. I suspect that the engineers didn't want to open the valves and allow KDSS to run in the softer configuration with the accumulators open because of concerns about heat buildup in either the pistons or the accumulator metal bellows. And they didn't like the harsher ride in the mid speed range.
Ride quality is ultimately a cost saving measure though. Toyota could have simply made a smaller diameter set of sway bars for the KDSS equipped TRD Pro models. That would be the best solution. But it is more expensive to build and harder to do the conversion at the port by adding another set of parts to replace. It's a lot cheaper and easier to just use a TRD OR w/o KDSS and convert it to a "Pro" than to do a more comprehensive changeover.
If you go back to the original TRD Pro models - they were primarily an appearance package more than performance package. They had the bilestein suspension setup that you could buy at the parts counter for about $600 for the full set. And the rest was appearance stuff. The current version has a lot more advanced shocks. It's more like a $2500 set of shocks now and probably does have some real advantages over the TRD OR w/KDSS. The original TRD Pro was in some ways a step down performance wise from a KDSS Trail Edition at that time. And it probably didn't make sense then to price it above a Limited that was the top of the price range. If they were doing a new TRD Pro now it might be more justifiable to go with maybe a more advanced KDSS like the LC300 gets to justify a higher price tag.
The original TRD Pro pre-production models were KDSS equipped. So I think it was intended to have KDSS at the design phase originally.
This is something Toyota should really address with the 6th gen in 2056 when it is released. The LC300 opted for two front pistons instead of one and I think that will help quite a bit. But it would also be nice to have the much longer travel that the LC300 and LC200 have in their KDSS designs. The other big difference is that the LC200 and I think LC300? (not sure on 300) is that it's not all or nothing - they have variable valve setups for the flow restrictions where the 4R version has shutter valves that are either all the way open or all the way closed.
The new tundra has some interesting new tech on its shocks that adjust valving on the fly as well, and that might be good enough to mostly replace KDSS as an alternative option. But I haven't really heard or seen anything about how the Tundra setup performs in real life. So it's a big unknown.
Just for fun
<iframe width="1010" height="568" src="https://www.youtube.com/embed/-_P_bZdlrw8" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
