5th Gen Spark Plugs- Photo Tutorial. So easy a 6 yr old girl can do it...
Jeff - you are wise to recognize the need to enjoy those special moments with kids. I make sure to include my two daughters (now 12 and 15) in occasional hands-on projects, home or auto related. They get to learn how to use various tools and we share the unique experiences and accomplishments that they do not have with anyone else in their young lives.
And nice write up, of course!
Thanks for all the compliments guys!
Grace keeps asking me how many "Likey's" she has- she gets a kick outta that.
PS- I love our Honda Odyssey- wife hates it. It does everything right for a family and then some...
Tell her I "like" her post 1,000 times. Check your text message.
[MENTION=65614]Antman[/MENTION] Well done Jeff. I really enjoyed it.
I have one suggestion: get Gracie her own (pink) gloves.
Is it me? Does she resemble [MENTION=47340]Titanpat57[/MENTION] just a little? Maybe it's just me ... yeah I'm sure it's just me ... NM.
Damn that sumbich!
Both his girls have a special place in my heart.....love em' like my own...wait a second...:hiding:
Great write up...Gracie's getting so big, and obviously way smarter than her old man....nice job!
Nice job on the write-up! Great pictures too! I have tried to get my daughter's out to tinker on the car with me but not to the extent you have! Great job!
However, as a perpetually, heart-broken Redskins fan I have to take away a point because of the Raven's T-shirt! Unless of-course it was the throw-away t-shirt so that it was no big deal if she ruined it working on the car. :lol:
I could care less about the Ravens or the Orioles, honestly. My wife knows more about that shit than me!
I would rather be on the water, in the woods or building something in the garage than watching that crap- but that's just me...
...Now that's adorable Jeff; your best thread EVER!! "...even though you did nothing at all to help the lil' doll" lol!
Great thread, Great concept, Great photos! ...great photos? (wassup with that?):noidea: "Long live princess Gracie"!! Best to you Jeff, and yours!!
Greg (rig)
Addendum for later models
How would Gracie negotiate the smog pump and lines on later model 5th gens ?...
Somewhere along the way...2012/2013, Toyota threw a bunch of emissions plumbing on top of the engine. That has to come off to get to several of the plugs.
Maybe [MENTION=65614]Antman[/MENTION] won't mind me adding here for the later models (2013+ I think) that have the air switching valves in the way of a few of the plugs. I wouldn't think there are too many folks that have many miles yet, but at some point it will come into play. With a 2016, I obviously haven't done this, so it's just pics of the interferences you'll have to remove. Sorry, I don't have the panache of Miss Gracie. You'll just have to bear with me on a boring writeup.
So this is an air switching valve that blocks access to a couple of the plugs. There is one on each side of the engine. They are not identically shaped due to mounting point differences, but other than that they are the same. The one shown in the picture is on the passenger side.
To remove the air switching valve:
1) First remove the attached air tube by removing the 4 bolts/nuts (yellow circles), 10mm socket. At each end of the air tube, there is a metal gasket. The gaskets will be replaced but be sure not mar the mating surfaces.
2) Disconnect the electrical connector and rubber hose from the valve (blue arrows). The rubber hose is attached with a standard spring clamp. Pinch the two tabs together with a pair of channel locks to widen the clamp for removal. Make sure you take note (or pic) of how the hose and clamp were aligned. There is a paint mark on the hose that lines up with a raised projection on the valve body. You will want the hose and clamp lined up properly when you reinstall.
3) Now you can remove the 3 mounting nuts (red circles), 12mm socket, and then remove the valve. The 2 that are visible are easy to get to. The one you can't see in the picture is behind that wiring harness. This nut may be the one thing that could complicate this job, so I'll focus on it for a second.
The FSM actually has you remove the air cleaner cap and hose before you mess with the air switching valves. The only reason I can see you would need to do this is for that one mounting nut on the passenger side air switching valve. So I recommend assessing this and trying to loosen that nut before starting this job. If you think you need to, go ahead and remove the air cleaner cap and hose before you start on the air switching valves. Here's how you would do that.
In the picture below
1) Unfasten the 4 hook clamps (red circles), just like your were replacing the air filter.
2) Disconnect the mass air flow connector (yellow circle)
1) Remove the rubber vacuum hose and detach the wiring harness (red arrows)
2) Remove the mounting bolt (yellow circle), 10mm socket
3) Sorry the next two are not pictured cos I was too lazy to take the engine cover off, but it should be obvious with it off
4) Remove the rubber ventilation hose, has a spring style clamp just like the hose on the air switching valve
5) Loosen the screw-style clamp on the hose where it attaches to the throttle body
6) At this point (unless I missed something) everything should be disconnected and you can wiggle and lift the air cleaner assembly out and set aside
With air cleaner cap and hose off, you should have no problem accessing all the mounting nuts and removing the passenger side air switching valve. For the driver side, it's basically the same except you don't have the air box in the way. After removing both air switching valves, you should be set up to do the spark plug replacement just like shown in the OP.
Installation of everything is essentially the reverse of removal. Just remember to get everything lined back up the same way. And also you're dealing with engine intake that is taking in air that goes through your filter so you do not want any foreign material getting in all that stuff during removal or installation, so keep it clean. Here's the torque specs for all the extra stuff and part #'s for the air tube gaskets, etc. that you'll need. I'll also point out that depending on your model year, the spark plug part # is different, so check that below as well.
Torques:
Air switching valve mtg nuts - 186 lb-in/21Nm (12mm)
Air tubes - 88 lb-in/10Nm (10mm)
Air filter hose clamp - 44 lb-in/5Nm (10mm)
Air filter hose mtg bolt - 44lb-in/5Nm (10mm)
Parts:
6 spark plugs
Toyota part # 90919-01233/DENSO SK16HR11 ('14-'16) or
Toyota part # 90919-01191/DENSO SK20HR11 ('10-'13)
4 gaskets for air tubes - Toyota part # 17377-38010
Hope this helps. First time doing something like this and I'm sure I messed something up or missed something. Certainly willing to take some feedback to make it better.
This whole time we thought you were the mod king when in fact its your daughter!!!!! LOL cute kiddo good times with the kids (sons for me) is always special.. Great write up as usual!!
The good times
One day your little one will be making her boyfriend make her sandwiches!!! Haha! Good job you two! Way to go for daddy-daughter time!
Torques:
Parts:
6 spark plugs
Thank you for posting this. I thought this was going to be an easy job but it looks like a little more work. I have a 2016 SR5, those two buggers (cylinders 2 and 4) will be more work than necessary. I wonder why Toyota changed this?
Most likely to satisfy emissions requirement(s) that kicked in the year these air switching valves were installed. Later-year 2nd Gen Tacoma's had this added as well. Unfortunately this air system has a tendency to go bad out of warranty. Owner cost is up around $2K as per tacomaworld.com.
Jhunt
