5th Gen Wheel & Tire Thread
These are what I have on my truck.
Enkei 18inchSILVERWheels - In stock!-6X139.7-18x8.5
Wheels - Ultra Gauntlet 17x9, -12 offset, 4.5 BS
Tires - Goodyear Duratrac 285/70/17
Suspension - Icon Stage 2
Body mount chop, front fender liner trim, front mudflaps removed
null_zpse5525d94.jpg~original
I think the first person to post Konig Countersteer Type X's with 285 GY Duratracs will instantly cover 90% of the 5th gen section...
Donezo lol.
-17x8 -10 Konig Countersteer X's matte black
-285/70/17 Goodyear Duratracs
-Spidertrax 1.25
-Toytec Ultimate Lift
Anyone else think this deserves to be a sticky? Great idea OP. Will throw up some pics and specs later.
What [MENTION=50186]adio3x[/MENTION] said, except not running spacers.
[MENTION=99783]snapple13[/MENTION] requested that we add the following:
- Body mount chop (if applicable)
- Any tire rub?
Makes sense to me, and I added them to the original post. Thanks again everybody, this is going to be a hell of an informative thread.
- Wheel make, model, size, backspacing/offset (+ spacers, if applicable)
Black Rhino, Peak, 22x9.5, +30, 1.25 Spidertrax spacers
- Tire make, model, size
Nitto, Terra Grappler, 285/50/22
- Suspension (if applicable)
ToyTec 2.5" front, 1.5" rear lift
- Photo(s)
below
nope
- Do your tires rub?
not after trimming and fender liner mod...
Sorry for the delay... was away on vacay in FL. Will get some better pics soon. Snowing and messy out there today.
Wheels: OE (for now. Wheels and Spacers to come in the spring)
Tires: Mickey Thompson Baja STZ 265/70/17
Suspension: 4 Bilstein 5100s. Front set @ 2.5". Rear 1.5" Daystar Spacers
Body Mount Chop: N/A
Tire Rub: N/A
<a href="http://s244.photobucket.com/user/newf_709/media/image-23.jpg.html" target="_blank"><img src="http://i244.photobucket.com/albums/gg4/newf_709/image-23.jpg" border="0" alt=" photo image-23.jpg"/></a>
<a href="http://s244.photobucket.com/user/newf_709/media/image-19.jpg.html" target="_blank"><img src="http://i244.photobucket.com/albums/gg4/newf_709/image-19.jpg" border="0" alt=" photo image-19.jpg"/></a>
Snows
These sure ain't pretty, but it's that time of the year.
"Let it snow"
- Wheels: FJC Steelies
- Tires: Bridgestone Blizzak DM-V1, 265-70 R17
- Suspension: Stock w/ 4 X Bilstein fronts @ .85
I still haven't had a chance to take decent photos, but here's my relatively new setup:
Wheels: Procomp 7069 17x9 4.75 backspace/-6mm offset
Tires: Goodyear Duratrac 285/70/17, D
Suspension: ICON Stage 5, but with their tubular UCA and no trailing arms yet.
Body Mount Chop: None
Tire rub: Haven't wheeled it with this setup yet, but on the street I've only noticed it once, but I was turning and braking spiritedly and simultaneously.
Fenders: Trimmed about 1/2" on that bottom front lip
Mud flaps: Removed for now
Finally decided on rims. Really would have wanted a wider stance but after all the research, I settled on an 8" wide rim to avoid any backspace and/or fender rub issues.
Enkei Performance M6 17x8, +10mm, BFG Rugged Terrain P265/70/17 (stock size)
Absolutely no rub, practically no visual difference fit wise from stock trail wheels and tires. Barely sit wider than stock, maybe 1/4". In the end, wife loves em so that's what counts. Her daily driver.
Wheels: Black Rock D window, 17x8, 4.5" BS, 0 offset
Tires: General Grabber AT2, 265/70-17
Suspension: Bilstein 5100, 1.75" front, 0 rear
Tire rub: Slight rub under left front fender in reverse.
Fenders: Will easily trim and adjust inner well when I get roundtooit.
Mud flaps: No problams
Wheels: Ultra Maverick, 18x9 -12mm offset
Tire: Goodyear AT Wrangler Adventure (265/70/18)
Suspension: Stock XREAS (Toytech 2.5/1.5 spacer kit in transit)
My tires rub, particularly the front driver side. As detailed in the post linked below, it seems to be a result of substantial sag on the front driver side. (The front passenger side rubs less.) I have chopped/moved the plastic in the wheel well without success. I have ordered the spacer kit above which hopefully will help.
http://www.toyota-4runner.org/5th-gen-t4rs/171989-rubbing-due-front-end-sag.html
How do you like the AT Adventures? I'm looking at probably going that route since I spend a lot of time on the highway. Pretty quiet and stable?
-SCS Stealth 6, matte black
-Goodyear MT/R kevlar 285/70/17
-Icon Stage whatever (kind of between a 2 and a 5)
-BMC (yes)
-no rubbing
On a separate note, really the only reason I posted in here is because I'm strongly considering going to 305/70/17 for my next set of tires (it will be a ways down the road) and I'm wondering how it can be done successfully with minimal rub... at a point in my turn, my tire is about 1.5" away from contacting the Shrockworks washer reservoir skid. That might be an inhibiting factor...
erinobr2000
