5th Gen Wheel & Tire Thread
Enkei RPT1 (18x9) wrapped in Cooper Discoverer AT3 XLT. (285/65/18)
I went with Fuel in bronze for my Voodoo Blue
Falken Wildpeak A/T3W LT285/70R17
Mamba Offroad M23's -12 Offest 4.53 Backspacing
3" BDS Suspension
I have a little bit of rubbing at full steering lock but will just need to trim the very bottom of the inner fender. I also took the front mud flaps off. Other than that I love the setup. No serious trimming needed and the Falkens have been great on and off road so far.
What's the ride quality like on that BDS kit?
Sent from my Pixel using Tapatalk
Upsized from a 285 BFG KO2 to a 295 STT Pro. These things are f'n beefy. Will have to do some more cutting, but so worth it
No wheel spacers but want some. Any recommendations of quality options?
- Enkei RPT1 18x9 et0 (custom Metallic Gold)
- Toyo Grand Country A/T 285/65
- Toytec Boss 3" (set at 2.5")
- Nothing Modified / No Cuts or chops
- Tires Rub fender liner with wheel locked in reverse
Nail in sidewall. Tires have 5900 Miles. Replace all four or just one?
2018 4Runner Limted. Yokohama Tires.
One Tire has a slow leak due to nail in sidewall. Cannot be patched. Dealer says all tires are at 9/32". He says its OK to replace just one tire.
Is this OK? Should I be concerned about the AWD drivetrain issues. Or is this negligible?
[MENTION=296623]danediz[/MENTION]
firstly, is it actually the sidewall? A lot of people who make money selling tires manipulate the anatomy of the tire. If the nail is in the contact patch/where the tread is, it can likely be repaired. Just try going somewhere else if this is the case. When installed correctly, patches can even be successful at the sidewall transition. Plugs are not my favorite but can be beneficial.
Assuming its not patchable...
Replace one tire or all 4?
I’ve never gotten a clear answer on this. My 2012 Limited manual doesn’t say anything about it.
Minimally, change 2 tires (2 front or 2 rear) and never cross them to front+rear.
What is your new tire tread depth? 15/32? Assuming so, you would have (15-9)*2/32” or 12/32” or 3/8” less diameter on the old tire if you only replaced one tire. The new tire would rotate fewer times per mile as compared to the one at 9/32” tread, which is what causes stress on the diff.
Based on that, I do NOT advocate changing just one tire.
The other advice I got - change all 4 and sell the other 3.
Did a quick test fitting of these TE37s. Still haven't bought tires yet :crybaby:
18x9, 0mm offset, stock suspension
I put a Motorcycle grip on mine and the flange keeps the bar from hitting the truck.....and it looks cool!
So where is a good place to buy TRD wheels from four a good price?
And apparently the consensus on the stock Dunlop’s that come on ORP’s is their trash...
What’s a good tire similar to them that’s not super aggressive? I want to maintain the same on road feel as much as possible as stock.
I’ve always just gone with Michelin M&S or Duratracs. I want to branch out a bit ☺️
I’ve always just gone with Michelin M&S or Duratracs. I want to branch out a bit [emoji3526]
My dealer said they would match prices I find online. You may want to check to see if yours will do the same.
285/70/17 Falken Wildpack on TRD Pro rims
I have the TRD Pro Rims on my 2019. I've considered selling them because they sit so far into the body. I really like the looks of them though. Not big on spacers. Your rig looks great. It's hard to justify buying new wheels because the TRDs look so good..... at least from the side profile.
Thanks. Yeah you are right. I mean Toyota did good job with design of those rims , just wish they would be 8”+ wide and better off set, to push it out of wheel well.
peacefulpiranha
