96 Hard Shift Issup Resolved (for free!)
jcush87
My 96 has had a hard shift for about a year and a half. I thought I had damaged my transmission by towing a 4500 lb boat regularly, but that wasn't the case. About a year and a half ago with the advice of this forum I tightened my throttle, cruise control, and Tra sissies kick down cables. I didn't notice the Hard Shift at first but it dawned on me 2 days ago that that might be causing my transmission to be prone to hold a low gear longer than normal. I was shifting out of 2nd at about 2900 rpm with a hard clunk. Yesterday I adjusted the cable back to where it originally was and no hard shift! The cable wasn't over tightened or anything, there was a small amount of slack but my tranny just didn't like it. I hope this may help someone else with a similar issue. Check your transmission kick down cable on the early 3rd gens.
THanks for posting. I wonder if the later 3rd gen models have a kickdown cable that can be adjusted? I will check tomorrow in the light. thanks for the tip
'01-'02 have no kick-down or cruise cable at all, since the throttle is electronically controlled. There's only one cable for the throttle, and that only opens the throttle plate halfway at max pull.
lilliagarcia
