Just came across your grille letters, and nice work, and creative thinking.
Not sure if it's possible, but anyway you can could scan your letter drawings? Or maybe a dimensioned sketch?
I'm impressed you got it to look so good by hand, how come you didn't use a dremel cutoff wheel?
What hasn't been said...the truck looks great! Do you still have your bilies on the top notch with the 99 coils? You have the perfect amount of space between the tires and fenders.
Looking good Phil! That is one clean wisconsin runner lol. :cheers:
What are your hub to fender measurements? I think I'm going to do the same lift but I'm driving an 02 so I'm starting a bit lower.
That's interesting. I always swapped the shocks and the springs when I was experimenting with springs. Your data point sounds like a good one, maybe find the shocks you like on 99s + spacer and 890s should ride similar.
I ended up running low damped digressive bilstiens with 99s and later 4x4 FJs. The stiffer OME springs and the shocks folks typically paired seemed to ride terrible without weight.
If you can deal with the free height, you might also check out FJ springs. My experience is they are stiffer than 99s and hold a bit of weight while maintaining Oe ride. Camburg makes a +2 which I'll get if I go higher.
Hey, I had responded to this previously but I dont know if you saw my question or not.
What are the "low damped digressive" bilsteins youre talking about here? I did some research and learned the difference between digressive and progressive shocks. What model bilsteins are you referring to exactly?
Did you list the truck for sale any time recently in the Philadelphia area? I assume not, because it looks so different now, but this picture:
Was on a listing (admittedly sketchy looking) on Philadelphia CL. Almost contacted the seller, but then found this build thread and your location and was like ??????????
No, definitely never listed my truck for sale. Was it actually this picture? Do you have a link to the thread? You've got me curious
This exact picture, the railings stood out to me in the background. Truck isnt for sale anymore, otherwise id link it. I remember being curious because it was listed for a very low $4k flat and I was looking at the time.
