A.Wilson013's Build Thread
Status
Not open for further replies.
Really??
This is not good news, the only thing I can think of is maybe the SS. Was it dealer installed new, or installed later in life? Sorry didn't want to cruise through your build thread to find out.
If so maybe they changed gears because of the power upgrade, so now you know you've been running 4.30's what's next? 4.56?
Pulled a rear 4.30 elocker diff last night in the gravel, in the dark. RIP to my elbows and knees.
Pulled my rear 4.10 elocker diff.
My 4.10 diff turned out to be a 4.30.
Lesson learned- every single list of "codes" for 3rd gens is incorrect, and you need to do the spin test to save yourself hours of labor.
I never understood the spin test...
I am no longer in need of a front 4:30 diff but If i do it again I wanna know how to perform this spin test so I don't have to take apart the diff and count teeth
just curious, why did you pull your diff?
Here is what I did.
1. Do not allow one wheel/wheel hub to spin. (i.e. leave it on the ground and only jack up the side you want to spin)
2. Mark where the diff connects to drive shaft and where the other wheel / wheel hub. I did it w/ some tape and a sharpie.
3. video record the spinning of the diff/drive shaft. (iPhone)
4. spin the wheel 20 times
5. go back to the video and count how many diff/drive shaft spins. (41 times = 4.1, 43 times = 4.3).
I need a 4.30 front diff, i just picked up a 4.30 rear locker. heres how I did the spin test. prevent one side from spinning and have your camera record the output on the other side, then spin the input 21.5 times, if the output spins exactly 10 times, you have a 4.30, if it spins 10.5 times its a 4.10. if it spins 9.5 times its a 4.56. 11 spins is a 3.90.
(Went to a junkyard, and) Pulled a rear 4.30 elocker diff last night in the gravel, in the dark. RIP to my elbows and knees. (Bought it cheap and brought it home).
Pulled my rear 4.10 elocker diff (to swap in the "new to me" 4.30 diff).
My 4.10 diff turned out to be a 4.30. (Oops)
So your V6, Auto, 4wd, SR5, "Highlander"... has 4.30's in it? I'm assuming you guys counted teeth and got 43/10, right? I wonder if the original owner special ordered the rig with the higher ratio.
If I were you (or anyone for that matter), I wouldn't waste the time or money chasing a 4.10 to 4.30 swap. It might be slightly noticeable on a stock rig, but on a rig such as your own, the results would be a let down.
Really??
The first SC was installed at time of purchase when new.
Some day I'll get 4.88's.
I pulled my diff because I "thought" after reading about 15 different "axle code guides" that I had 4.10's, and wanted to upgrade to 4.30's. It was free, so I thought it'd be worth a shot to see how much better my 4Runner would perform.
Basically trying to get a bit of my acceleration back that I lost when I stepped up to 285/70/17 Duratracs.
Yessir, has 4.30's in it. And yes, counted teeth about 17 times at a little after midnight. At first I thought it was funny, and a good learning experience. 2 hours later, while still scraping the old gasket off, I changed my my.
The only reason I was going to try the 4.30's was because they were free. Hard to be too upset about results when all it cost was a Friday night.
4.88's will be had, but probably not for quite awhile.
Also... I don't understand your bolded additions to my post. It's 2:00am... That may have something to do with it.
So my question to you is what is the code located in the door jamb? Ao3a or Ao4a?
What is this mysterious code you're asking about? Haha...
What I would give to have known that code existed.
It's AO4A, so it was installed at the factory.
I find it so strange how few people know what those codes mean. Every thread or "guide" I have EVER seen on this topic lists the "Model Code" and makes no reference to the axle code.
But again, I did learn a thing or two about pulling a diff/e-locker and also about not trusting what you read on the interwebs.
My Toyota parts-counter axle code sheet says A03A = 4.100 and A04A = 4.300. Is this what you were reading?
Alex,why don't you come drive mine and see if you'd like 4.88's. We have a similar drive train/power plant. I'm a little rusty but I can setup your gears for FREE if you decide to go new for 4.88's
You've got a 5 speed, mate. I don't think it'll be very similar.
Someday though.
Status
AndiGarage
