Chris Sandstorm
No its a pretty straight forwards deal...2 things I can lend a tip towards
1) Spray down your bags with wd40 so you can slide them easily in between the coils. Once you squash them down and hold your finger over the nipple, they should slide right in.
2) For the bump tops, there is enough room to get a razor blade and "push" your way through wearing gloves and using needle nose or anytype pliers. A new blade will cut through fairly easily. All in all I didn't even have to jack up the truck, just rolled right underneath it.
Hope this helps
Yes thanks for the tips, except I just got started this afternoon and never logged back in ...haha
Oh Well...
I used soapy water to get the airbag to fit. I have ToyTec's super flex coils, so longer then stock or OME 2.5 inch.. Needed a ton of space to get the OME Coils out and the Tpytecs in.
I had run the Toytecs originally but were too squishy once I loaded all my gear fro trips...Had a very new set of OMEs that I felt were to stiff (mediums) for my FJC.. I tried them on the 4runner, felt the same too stiff for everyday..So back to the ToyTecs with Airbags..
Really seems like I might have a good combo, we will see. Heading to Canyonlands in 9 days, will test them out for sure!
Here is my supervisor checking my work...
