Another Backspacing & ET Question
BrianSD_42
Hi,
After reading a few threads about backspacing and aftermarket wheels here is where I'm at ....
I still can't figure out which aftermarket wheel (size choices below) will be closest to factory in how it sits when looked at from the street.
And two which one will be slightly further out.
I know based on several threads that the factory 5 star 4Runner wheel has backspacing of about 4.62"
Which wheel will be close ? (again when looking at the truck on the street) ...
Which one will stick out 1" (or what) further than what I have now?
Factory Wheel: 16x7, 4.62" Backspacing, ET: ?
My Wheel Choices Options:
Bolt pattern 114.3mm / 4.5", with ET 0
BP 114.3mm / 4.5" , with ET -10
BP 139.7mm / 5.5", with ET 0
BP 139.7mm / 5.5", with ET -10
:suspicious:
Closest will be the 4.5 BS with ET 0 I believe, but those are 114.4mm wheel spacing right? Remember that those wheels are probably 16x8 or 8.5, so they will already stick out .5" if they were the same BS and Offset as stock rims. I'd go with the 4.5/0 if you want a more stock look as they don't stick out super far and will reduce rubbing and contact with the UCA.
TerryNap61
